Twinscroll + HTA
Old Aug 28, 2008 | 07:47 PM
  #31
03whitegsr's Avatar
Originally Posted by evodan2004
i still cant believe people are still so uninformed and have yet to see why TS is what it is. i guess you really just need to drive one to know.
If people would just look at a stock IX turbo powered car it should be pretty obvious.
immediate spool
incredible mid range power
huge total power for the size of the turbo
10 second passes when well setup from a turbo that choke flows at what, 40 pounds/min?
Obviously if the stock turbo is so capable with such a small compressor, it should be of no surprise that upping the size of the turbo will have the same end effect.
Old Aug 28, 2008 | 08:42 PM
  #32
hokiruu's Avatar
Originally Posted by rxw
Like Geoff said, just because people don't post results all over the internet doesn't mean it doesn't work or hasn't been tested.
I've been looking for a very long time for the ultimate street combo (like everyone else). Being NON biased toward ANY tuner/tuning house or any workshop because I’m in Australia it’s opened my eyes a little to see people's true colours.
So many people become fan boys because of marketing techniques and the “sheep” type of mentality. If you spend the time to look around at the hard data and cipher though all the opinions you will find twinscroll works, weather it be on an 4G63, EJ25 or SR20. There is plenty of hard data available that proves TS works and works VERY well when set up correctly.
When a workshop or individual say XYZ about someone else’s product that doesn’t mean you should take it as gospel, if you respect them and trust them, great but be aware of their under lying agenda. Lets say ‘EVIL-Workshop’ has the best GT35r kit out there and everyone uses it and LOVES it. It has probably taken a massive amount of development and time to get all the parts working in harmony from the built block, heads, cams, intake etc, but once they have the working combo is fantastic! Then ‘EVIL-Workshop’ tests a twinscroll setup and don’t like it, they probably didn’t spend the time to find the combo that made it shine like they did on there own kit. It’s just an example and take it as you will.
I think Full-Race has been beaten on and if you actually spend the time and find out the data for yourself you will see. Granted a lot of people don’t have the time and I suppose this is where a lot of the ‘opinions’ come from. Full-Race stuff works, get the right combo and you won't be happier.
On a side note I have never seen Geoff act anything but professionally on EvoM, NASIOC and IWSTI, not once have I seen him say a bad word about a competitor’s product or a person. It’s rare to see that these days.
areed (sorry roken keyoard s spilled whiskey on i rih now!)
Please bear with me, I just want to verify:
So HTA still uses a Garrett turbine, but a Borg Warner compressor wheel?
Geoff, are you saying that you feel since HTA is basically stuffing a larger wheel into the same size housing, it negates the maximum benefits of TS due to the fact that it doesn't allow one to take advantage pf the maximum benefits of TS with a larger housing?
Old Aug 29, 2008 | 08:32 AM
  #33
scorke's Avatar
Geoff doesnt it use a non garret compressor wheel?
Sorry for the confusion
Scorke
Old Aug 29, 2008 | 02:49 PM
  #34
Geoff Raicer's Avatar
i consider a "mismatch" turbo to be any turbocharger who's compressor wheel is larger than the turbine wheel can comfortably handle. This size can either be a large diameter or it can be a high flow rate that is outside of that turbines comfort zone. Mismatch turbos appear to work well in a single scroll config, because 4->1 designs mask turbine inefficiencies, so slight drops are hard to notice. Some production turbos i consider to be mismatches are: GT4094R, GT3082R, 35HTA
for a twinscroll system to work optimally, the turbine efficiency needs to be spot-on, and that is very hard to attain with a mismatch turbo
Old Aug 29, 2008 | 03:30 PM
  #35
hokiruu's Avatar
Thanks for explaining that Geoff!
Old Aug 29, 2008 | 05:50 PM
  #36
weap0n's Avatar
Here is my twin scroll kit from ETS. Its a HTA35R with the 1.06 AR exhaust housing. Its currently somewhere between the USA and Australia. Once it arrives and I have all the other parts I will install it, get it tuned and turn up the boost to give some results on how it performs.
Old Aug 29, 2008 | 06:03 PM
  #37
JeffMas1587's Avatar
sexy looking system cant wait to see it installed
Old Aug 29, 2008 | 06:52 PM
  #38
Jasil's Avatar
I will only chime in to say that what we still haven't seen in the US market, at least on a EVO, is a maxxed out 35R, 4088, or similiar setup pushing 36psi+ on a fully built setup.
Still waiting, but I will agree very much in the spool difference!! It's there.
Old Aug 30, 2008 | 05:17 AM
  #39
sparky's Avatar
Originally Posted by crcain
I posted opinions about the Evo kits nothing else.
EvoM is an open forum, C.R., and anytime that Simon Norris wishes to comment or otherwise express his opinion, he is welcome to do so personally. There is absolutely no need for you to serve as proxy.
Old Aug 30, 2008 | 08:43 AM
  #40
crcain's Avatar
Sparky that is your opinion, of course I disagree, but respect your opinion all the same.
What I read about the vertical IC in that thread I thought was worth sharing alone.
Old Aug 30, 2008 | 04:40 PM
  #41
Ted B's Avatar
Twinscroll works. Your EVO came equipped with it, and every factory sized turbo through the FP Red has it. It's a big reason why these turbos are so responsive on the street, and something as small as an open 3071R absolutely is not.
Whether or not you can make TS work for your large turbo application depends entirely upon you. If you configure it properly for your application, you'll be completely satisfied. That isn't as easy as it sounds. We're still learning, and so will you.
The only way one can truly evaluate a TS setup is to drive it on the street, not dyno rollers. The end.
Old Aug 30, 2008 | 04:46 PM
  #42
crcain's Avatar
Teddie B!
I know twin scroll works , but I guess the ultimate question is, do the particularly configured kits from Full-Race work that customers actually get once they send 7k FR's way. And the answer is well I guess sometimes but maybe getting better?
That was my only point. And also the effectiveness of the vertical flow as well is an issue I thought was worth bringing to peoples attention.
Old Aug 30, 2008 | 06:10 PM
  #43
johnd's Avatar
Teddie B!
Full Race will sell you a kit, half a kit or just a single part such as their manifold. It is up to you the individual to spec the kit for your personal application, including turbo housing,(only people I have seen complain about theirs kits are those who order std kits without knowing if it suits their spec) as every single build is different from the next one.
If you require help in putting together a kit then contact Geoff - a more knowledgable and pleasant guy you will probably not come across - and he will do his best to help you out and advise you
The vertical flow intercooler was added to these kits as the kits were designed for a responsive set-up. Hence the twin scroll, shorter pipework - all to aid spool. It's all about give and take. You gain the spool but lose out on the IAT as was clearly evident when the kits were launched. If you want lower IAT's then use the horizontal intercooler.
Feels like people are beating on Full Race here without understanding how to properly configure a twin scroll setup.
John
Old Aug 30, 2008 | 06:38 PM
  #44
Turbo Kyle's Avatar
Cant wait...is that a T3 TS?
Old Aug 30, 2008 | 11:13 PM
  #45
weap0n's Avatar
T4 1.06 Ar
