CEL: Random misfire code???
Old Sep 25, 2008 | 08:03 PM
Knguyen228's Avatar
I have a CEL on and went to autozone to scan it. Got a random misfire code. Is that normal for my car with all the mods I have? Also, I have already replace my spark plugs when I was having my car worked on.
Old Sep 25, 2008 | 08:10 PM
sharkm87's Avatar
recheck gap maybe
Old Sep 25, 2008 | 08:16 PM
vvhiteix's Avatar
hey...welcome to the world of cams....how long have you had your cams in for? and your on the stock coil plugs i assume? stock ecu?
Old Sep 25, 2008 | 08:22 PM
Knguyen228's Avatar
I just notice the other thread about this. So the tranny or clutch would cause this code to come on??? The car dosen't feel like its misfiring. I do have some sort of annoying sound coming from what I think its from the clutch and my differential.
Another question, My differential seems to be really loud(whinning), so do I have a bad differential?
Old Sep 25, 2008 | 08:24 PM
Knguyen228's Avatar
stock ecu and coil on plugs. I have had my cams for 2 weeks, I have a thousand miles on them now (Long drive from Orlando to Mississippi).
Old Sep 25, 2008 | 08:27 PM
2muchboost's Avatar
I got the same code when i put my cams in
Old Sep 25, 2008 | 08:34 PM
Knguyen228's Avatar
So it seems it cause by the cam. oh well
I need some help with a whining noise though. I think its from the differential because when I sit in the back seat, its way much louder then the front.
Old Sep 25, 2008 | 08:40 PM
LittleBlueMnM's Avatar
Your Walbro fuel pump maybe?
Old Sep 25, 2008 | 08:45 PM
Knguyen228's Avatar
^^I only hear it when im driving.
Old Sep 26, 2008 | 01:41 AM
1NastyMR's Avatar
I got the same code my cams throw the code every here and there nothing to worry about
Old Sep 26, 2008 | 08:38 PM
vvhiteix's Avatar
yea... well when my code pops on... my idle is a lot rougher. in my case that is... but...its something to look into...i know there is a fix for evo 8's they swap the rom's but... i also know that... our plug gap should be slightly smaller with cams.. i just havent researched enough to know what to regap them to.
Old Sep 27, 2008 | 11:37 AM
sonicnofadz's Avatar
I've had this code come up a million different times, and guess what, every single time it appeared, it was for a good reason, I had a vaccuum leak. Check for leaks, I'm willing to bet a million dollars you have at least one small one somewhere. Check all vaccuum lines, including all the tiny ones behind and under the intake manifold. Now that my car is leak free, it never shows up anymore.
Old Sep 27, 2008 | 03:15 PM
vvhiteix's Avatar
well i agree with that...but...in our case... directly after the cam install its not like... we were driving with they for months or weeks then the light came on...its directly related to the cams..... and the tune... timing block jumps... input shafts...etc...
Old Sep 28, 2008 | 06:33 PM
NoTn41's Avatar
mine is doing the same thing! how do we completely get rid of this code?
Old Sep 29, 2008 | 03:41 PM
vvhiteix's Avatar
i dont know... i dont think there is a complete fix for it.
Saint47
Feb 23, 2017 11:42 AM
Brsox10288
Dec 28, 2010 04:03 PM
Wayne99gsr
Northwest Region
32
Dec 10, 2008 06:05 PM
16ggst
21
Jan 9, 2008 02:09 AM
[Cyanide]
Feb 1, 2005 12:18 AM
