FIC injectors: Am I being paranoid?
Old Oct 7, 2008 | 03:56 PM
Ted B's Avatar
Originally Posted by Mike@AwdMotorsports
They are not always the same.. Look at the 1600's from FIC.. they are white tops which i have seen issues 1st hadn with on 2 occasions.. Precision sell the Blue Top which i have never ever had an issue with...
1600cc injectors (at least those I've seen) are a different animal altogether, and are not representative of the ones sized through 1200cc. The 1600s are pintle type injectors, and I would never use a pintle type on a high specific output application, period. You're better off using a set of aux injectors if you need that much fuel.
Old Oct 7, 2008 | 04:00 PM
AWD Motorsports's Avatar
I guess its all what your comfortable using.. been using the blue tops in all my cars since 2000 when i was making 600hp on a 4cyl.. never an issue, so i stick to what i have had luck with.. If you were local to FIC you would see what i see..
I am not 100% sure but i think the white 1600's are all remanufactured.. Cannot say if a lot of the smaller sizer as also..
Mike
Old Oct 8, 2008 | 02:19 PM
mrfred's Avatar
Mike
Ted B is correct on everything he said. I've worked with FIC on a few little projects and found Jens to be a straightforward, knowledgeable guy who wants to make the best product possible.
Old Oct 8, 2008 | 02:23 PM
Ginglingston11's Avatar
definitely PTE and i think they are usually the cheapest anyway
Fuel Injector Clinic
Nov 30, 2015 04:55 PM
awhit17
Sep 19, 2015 02:38 PM
mrfred
Apr 17, 2015 09:38 AM
Shaun@AWDMotorsports
EvoX 'For Sale' External Engine / Power
12
Jan 31, 2014 08:20 AM
420a-t
Jan 12, 2014 11:29 AM
