ACD transfer case specs
Old Oct 21, 2008 | 06:20 PM
milruner's Avatar
I was just wondering if anyone had a spec chart or a how to reassemble a 05 EVO MR transfer case, looking for all the spec's and back lashing, trying to put my transfer case back together because i put a new Differential in , and cant find any of this info anywhere. Someone please help me would like something with pictures, with all the specs and everything i need to put it back together.
MIKE
Old Oct 21, 2008 | 06:31 PM
1NASTYIXMR's Avatar
Your going to buy a factory service manual unless someone has one on here.
Old Oct 21, 2008 | 09:06 PM
milruner's Avatar
maybe someone has one hopefully, just need those pages copied, and sent or shown to me that's all, plus my dealer sucks, have a buddy that works at Mitsubishi, and they don't even have one at the shop. or else he would of took it for me, and they dealership doesn't even want to buy one he said.
MIKE
Old Oct 22, 2008 | 10:35 PM
cchan3761's Avatar
Hey I got one but I'm a little busy right now, I'll let you know when I can get it up
Old Oct 23, 2008 | 09:20 AM
JohnBradley's Avatar
MIKE
Dealerships dont rebuild transfer cases since they cant get parts. IF all you did was change the diff the backlash hasnt changed since its still the same carrier (that is if it is the same carrier).
Old Oct 23, 2008 | 06:04 PM
cchan3761's Avatar
Milruner do you still need the pages?
Old Oct 24, 2008 | 02:36 AM
M5150's Avatar
http://www.poweraxel.com/archvs/rall...vo6/cp_lsd.pdf
Here are some instructions for the evo 6 (I couldn't find the Evo8 instructions), the torque values are the same. The only thing you must be sure about is to put the bearing preload shims back where they were and you should be good to go... but if you insist on checking the backlash, you can remove the 4 10mm bolts on the small zinc plated cover and check the backlash of the assembled differential from that window... if my memory serves me right it should be .005" or there abouts...
Hope that helped,
Max
Old Oct 25, 2008 | 05:42 PM
milruner's Avatar
a cchan if you could give me the pages that would be helpful, wouldn't hurt, gonna be starting to put back together on monday, so the more the helpful it would be.
MIKE
Old Oct 25, 2008 | 07:18 PM
milruner's Avatar
Hope that helped,
Max
a i tried opening this one that you gave me and it wont open.
MIKE
Old Oct 25, 2008 | 07:24 PM
vtec2mivec's Avatar
I haven't checked on the transfer case specs, but it's worth a shot http://issuu.com/onderhoud/docs/manual
Old Oct 25, 2008 | 09:50 PM
milruner's Avatar
thanks for all the info guy, and gals if there is any giving me info.
MIKE
milruner
Jul 19, 2021 05:37 PM
eXtreme-Speed
Dec 30, 2016 01:27 PM
billybond_09
Aug 3, 2015 11:10 AM
psphinx81
Dec 25, 2009 09:42 AM
boostinscooby
11
Aug 25, 2009 06:09 PM
