just installed FP red. have some q's
hey guys,
installed FP red.
mods are as below except have a red instead of green now.
want to switch to E85. going to get 1000 or 1200 cc injectors. stock ecu car.
do i need br double pumper? or can i get to 450ish awhp safely on a single walbro?
ams will be tuning the car, their only options for bigger fuel is there 1400 dollar 1000 hp set up, or a 700 dollar dual pump with surge tank option. id rather just do a br double pumper then all that, however can i get away with just larger injectors and getting tuned?
thanks.
installed FP red.
thanks.
An AEM EMS is not needed, and neither are 1600s. It takes all of one minute to retune the factory ECU to run cleanly on E85, and 1000cc injectors are fine for 450whp.
A Walbro 255lph unit, just dropped into the factory wiring harness with no other changes, will just barely deliver enough for 450whp, and will begin showing the reduction in line pressure as elevated IDC. The double pump setup is the most convenient option. And if you do go that route, you probably want to go a little bit larger on the injectors just so that you're not limited by injector headroom if you decide to push it a little harder.
i doubt you will NEED a twin fuel pump setup...
i have seen 1 walbro support very high 600whp, ams 37r kit, built 2.0l (on accident, one of the pumps wasnt wired up right), no problems, untill beyond ~36psi, c16....
I have also seen a couple 30r evo's around 28-32psi on c16 running 1 walbro with 1000cc, with no issues either, both made a little over 500whp, one built motor, one stock bottom end.
But I probably would go with a twin fuel pump setup for the Red, 30r, or bigger, just in case, especially with e85...
walbros start to have issues at around 580whp, so you are totally fine on 450 range. Keep in mind that e85 weighs less and your walbro will flow more as a result. I have been running 550 range on 1000cc densos and a single walbo for over 8 months now on a steady diet of e85 and 24 psi tapering to 23:
On the other hand, lots of vendors want to sell you stuff :P
I don't think you will NEED a dual fuel pump setup but it will help. This guy over on SCE is making 490 WHP on a single Walbro and 1200s and just other normal bolt ons.
http://www.socalevo.net/index.php?op...&topic=68381.0
Might need to register.
