revolver 264s vs kelford 272s
Old Oct 22, 2008 | 10:39 PM
booster9's Avatar
hey i bought some kelford 272s a few weeks ago.. i am extreamly happy with them, however with 11mm lift springs are recommended.. im starting to hear something that sounds very bad at idle every once and a while... i think it might be valve tap..
so i came across a deal that someone will trade me revolver 264s (11.5 mm in 11.4 ex) WITH springs BRAND NEW, for my kelfords and stock springs.
is this a good deal? are revolvers any good? i searched for a while and didnt find the info i wanted, all of them where FS REVOLVER CAMS
Old Oct 22, 2008 | 10:47 PM
projectevo9's Avatar
Don't do it. Keep your Kelfords and if your reving higher than stock buy dual springs and retainers.
Old Oct 22, 2008 | 10:49 PM
booster9's Avatar
na im not reving higher than stock.. i just have this scary *** drivetrain noise.. its not dirty lifters it seriously sounds like the valve is taping the piston.
Old Oct 22, 2008 | 10:54 PM
wow.... how long have you had them for?
Old Oct 22, 2008 | 10:58 PM
booster9's Avatar
about a month... when i bought them people where saying that you didnt NEED them for the kelfords... but im scared im going to f*** my valves...
soulds like a woodpecker pecking solid metal
Old Oct 22, 2008 | 11:00 PM
nikkadanny's Avatar
ill trade you my brian crowers 272s for you kelfords=)
i didnt know revolvers made cams for the 9's
Old Oct 22, 2008 | 11:04 PM
booster9's Avatar
yeah i cant seem to find any revolvers for a 9 on any websites... oh well... now i gotta replace my springs...
Old Oct 22, 2008 | 11:59 PM
john.schuber's Avatar
just get springs and retainers
Old Oct 23, 2008 | 05:44 AM
nitz's Avatar
i run these.
there are no revolvers for ix's. these cams have not been manufactured for some time now. they are a very torquey cam like you would expect with high lift and short duration. there have been quality control issues with both the cams and their springs. i wouldn't run a single set unless i could degree the cams (mine were 11 degrees out of spec on the intake cam), and probably wouldn't use the springs at all. this is why you see them in the for sale section for sometime now. however, they do make gobs of torque/power when they are good (i ran 11.0 with a 1.8 60' on my green with them).
Old Oct 23, 2008 | 06:19 AM
Dave@TTP's Avatar
I made 462WHP on pump with these cams.
Old Oct 23, 2008 | 06:26 AM
Migsubishi's Avatar
From what I have read the Kelfords are an amazing cam, did awesome in the AMS cam test as well. You would be nuts to take them out your car, get springs and retainers then degree the cams!
Old Oct 23, 2008 | 06:28 AM
Ebirns99's Avatar
I love the Kelfords that ams installed I made good power on stock turbo and can't wait to swap turbos. Great top end power
Old Oct 23, 2008 | 08:52 AM
gsrboi80's Avatar
The valve train noise is likely due to your lifters man. You can try the in car bleeding proceedure as outlined in the FSM. If not out they come to bench bleed them
Old Oct 23, 2008 | 08:56 AM
Ted B's Avatar
And those people probably do not understand the first thing about valvetrain dymanics, and why the cam grinder has determined that upgraded springs are required for these cams.
Do what the cam grinder tells you that you should do, and you will be ok.
740 Turbo Brick
Nov 8, 2015 12:24 PM
rocketmotor
Aug 4, 2013 12:35 PM
PsychDr. HN$
16
May 8, 2012 11:52 PM
KevinD
Apr 18, 2008 12:48 PM
timzcat
188
Mar 3, 2007 10:53 AM
