crank pulley?!
Old Dec 9, 2008 | 03:30 PM
VRSF Tiago's Avatar
Originally Posted by biggie5252
So I noticed that after I tightened my bolts, the vibration has gradually gotten worse again. I looked at it with the engine running and it was shaking pretty badly. Today I decided, with the help of the weather, to actually pull it off and see if it was damaged somehow. Well the vibration, I'm assuming from the loose bolts, actually wore away the bolt holes. They're no longer round. It has pushed the little key on the timing belt pulley back into pulley, therefore it's not really being held in place. Definitely time for a new pulley.
If you're having the same issues, you might wanna get it checked out!
If you're going to replace it either replace it with an OEM pulley or go with a Fluidampr. Just make sure the pulley you go with has the ability to dampen and not just reduce weight.
The "lightweight" pulleys will do more damage than they are worth.
Joshs EVO's Avatar
I had a issue like this a few months ago but my problem turned out to be something differnt.
My A/C motor bracket broke which then put the A/C pulley at an angle making the blet jump all the grooves and led to the belt fraying. We didn't find this out until I went through another belt within a few days. Then we looked at what was going on closer and found it right away. SO we just used a A/C delete belt and left it the way it was for the time being.
problem solved.
Old Dec 9, 2008 | 05:13 PM
biggie5252's Avatar
I ordered a fluidampr. I wanted to get one anyways, just not right before Christmas. Hopefully I get the aluminum version. I asked for it, hopefully they realized that, and that's what I get. Either way, I'll be happy.
I checked the belt and it looks good.
Evo47
Mar 4, 2020 03:21 PM
AutoXMRIX
Mar 9, 2016 07:02 AM
onix175
Lancer Engine Tech
Feb 19, 2016 04:54 AM
Blue04ES
Lancer Troubleshooting
Oct 6, 2010 05:02 PM
billevo1x
15
Oct 4, 2009 05:01 AM
