BOV Flutter?
Old Nov 20, 2008 | 04:04 PM
7he1and0nly's Avatar
BOV Flutter?
Ok so I have an AEM Short Ram intake and since install the BOV is def louder (of course) but when I am at low speed or RPMs and let off the gas there is a flutter. Something to worry about or just normal. From what ive been reading could be a leak somewhere or the BOV is failing?
Old Nov 20, 2008 | 04:07 PM
Jeffs2006EVOIX's Avatar
Your Post
The Flutter sound is normal....especially under deceleration. Its the Air from the Turbine bouncing off the throttle plate, makes a fluttering sound...only thing I didn't like about my AEM intake is the loss of Torque. I knew that would happen, but I dropped from 340wtq to 330wtq just by installing my intake, but I needed higher flow for the cams I chose, and the futrue turbo upgrade I am planning. Each part added on, has its pros and cons.....that is for sure.
Old Nov 20, 2008 | 08:32 PM
AznDragonV's Avatar
after i installed my injen intake, and with my forge rs bov. it started to make a flutter noise shifting at low rpms. i searched around and i found it could be compressor surge
http://www.youtube.com/watch?v=LZUbo...eature=related
if yours sounds like that..your turbo COULD be surging ..im not saying it is.. but its a possiblilty. just watch out. IF it is surging, try adusting your bov all the way soft. thats what i did and it went away ( thats if you can adjust your bov)
Old Nov 20, 2008 | 08:46 PM
the post
compressor surge is a possiblitity, but unlikely if using the stock BOV. Unless its defective? But we can't rule it out. That is for sure.....Good Call.
Old Nov 21, 2008 | 05:20 AM
cthcky5's Avatar
at low boost u might surge. but u shouldnt worry about it. if u surge at hight boost, than u have problems
Old Nov 21, 2008 | 03:14 PM
sparky's Avatar
Originally Posted by Jeffs2006EVOIX
The Flutter sound is normal....the Air from the Turbine bouncing off the throttle plate, makes a fluttering sound...
The charge air exits the compressor, not the turbine.
Old Nov 22, 2008 | 09:54 AM
4DR's Avatar
4DR
I'm sure its a flutter. When you have partial boost, there is not enough pressure to force the bov spring to open, therefore the air hits the throttle plate and bounces off. Enough of this and you can damage your turbo. This why most bov (the good ones)are sold with different springs. My tial has a stiff spring in it and I flutter all the time. I need to change mine as well. My advice is to get a bov with a softer spring that won't leak at high boost.
TIAL!!
Old Nov 22, 2008 | 09:57 AM
porsherules911's Avatar
I can hear this flutter when I'm boosting maybe less than 5lbs then let off the gas. Very faint sound though.
Old Nov 22, 2008 | 10:02 AM
4DR's Avatar
4DR
See my post above. Remember, too soft of a spring can create idle issues.
Old Nov 22, 2008 | 12:35 PM
23r0k001's Avatar
with am APS BOV i get this and actually tightened it to stop it at low boost. I will definitely loosen it up in about 2 hours.
Old Nov 23, 2008 | 02:46 PM
Hmm good to know, since I still have the stock one it cant be adjusted but it is for sure only at low RPMS and very low boost. So all should be good. Im gonna check that vid on utube AZNDragonV Thx for the link :-D
Old Nov 23, 2008 | 06:41 PM
Ok so after looking into when the fluttering is going on (just to be safe) its only heard when im at 2100 or less RPMS lol so veery low boost. and only if i let off the gas slowly, if i release quick there is no flutter.
Jeffs2006EVOIX - the AEM intake makes you loose 10wtq hmmm interesting, you got a explanation of why?
Old Nov 26, 2008 | 12:57 AM
AznDragonV's Avatar
np. i was under the impression you had an aftermarket bov..
i never had fluttering with my JDM MR DV. But with my forge rs now.. in 5th gear, if i let off the gas slowly on the highway. it flutters.. myabe even surging. gotta talk to my tuner.
Old Nov 26, 2008 | 07:07 AM
travman's Avatar
its compressor surge...........the "bov" is not "fluttering". The stronger the spring in the valve the more prone it will be to surge because low pressure at low loads it can't open the valve and you get that charge going back into the compressor.
Its no big deal, low compressor surge wont hurt a thing.....I hear it from time to time on my IX w/ stock metal dv.
If you want it to stop put a VIII stock plastic dv in and then don't gripe when it wont hold boost.......
zcool1986
Lancer Aftermarket Forced Induction Tech
28
Feb 3, 2014 02:33 PM
lpy2009
Feb 26, 2012 12:09 PM
HPEVOX
27
Apr 14, 2010 06:23 PM
06GraphiteEvoIX
32
Mar 11, 2010 08:45 PM
dvd_mi
Mar 1, 2010 03:02 PM
