Solution for the Trasfer Case issue...
o i bought an evo ix and faced the problem many had... the transfer case problem. as i asked here and there i understood that this problem is because of the AYC rear diff and changing it into a mechanical diff (like the rs) will solve the problem.
can you please help in this matter... any ideas?!
well mine is a ix (tuned) and seems that the TC cannot handle it. although i know another guy who has ix rs, which has the same TC but mechanical diff rather than electronic AYC or S-AYC and never had any issues with the TC.
What kind of issues are you having with the T-case? The whine, or did you blow it up? There are plenty of guys here making big power, it's all in how you treat it. I know...I just had to shell out some serious cash to Shep for a TC and trans rebuild.
Hello I have a built 5MT shep transmission stage 2 and a shep T/C stage 3 and on the rear a have an OEM aluminium case diff on my Evo IX GSR european model.
Do I need to change it to RS differential?
sounds like a clearance issue in the t-case. they seem to be set up a little loose from the factory and the diff will actually "walk" a little in the case when it is loaded up real good. definitly sounds like a tc rebuild is in your future, it's a big investment but way worth it.
