problem after clutch install HELP
Old Nov 29, 2008 | 09:27 PM
Jersey Dino's Avatar
I put my exedy twin in. everything appeared to be fine. It started and drove. I had a little sputter so I thought maybe a charge pipe was loose or acd needed to be re bled. came back try to try and take a quick test drive and its stalling and sometimes not starting. it did give me a vehicle speed sensor error before. I am going to take it back out and take a look. any suggestions? also how much noise/chatter do these twins make when the clutch is pushed in? sounded loud but was also barely keeping an idle. any help would be greatly appreciated. thanks in advanced
Old Nov 29, 2008 | 10:03 PM
update. removed the vehicle sensor and reinstalled it. no signs of damage. no cel after a few minutes of running. BUT now the car idles a few minutes comes down and just drops really really low everything shakes and it stalls out. any ideas what the hell i could have done along the way to installing this thing? btw NO CEL
Old Nov 29, 2008 | 10:05 PM
PeteyTurbo's Avatar
hi
Old Nov 29, 2008 | 10:15 PM
huevosrancheros's Avatar
bump
Old Nov 29, 2008 | 10:19 PM
PeteyTurbo's Avatar
is there gas in the car?
Old Nov 29, 2008 | 10:20 PM
red evo8's Avatar
check vacuum lines if you forgot to reconnect any?
Old Nov 29, 2008 | 10:38 PM
Duh Panda's Avatar
maybe a vacum line.. did you reconnect ALL the sensor?!
Old Nov 29, 2008 | 11:00 PM
all sensors appear to be connected. nothing really comes apart to drop the trans. its just the speed sensor and back up light up there...
Old Nov 29, 2008 | 11:08 PM
update for everyone who was so helpful here. apparently these things need gasoline to run...put 5 gallons in and what do you know. the b!tch runs...wow I feel retarded. at least i got the install done with out any real hicups...
Old Nov 29, 2008 | 11:10 PM
I havnt driven it in a week and now that I jogged my memory I remember needing fuel badly and pooched it home with the intention of doing the clutch job and then getting it. Why? I dont know probably lazy after a 12 hour shift...
Duh Panda's Avatar
wow man! jus WOW!!!
good job.. not everyone can do a clutch swap on these *****es!
drink up man!
Old Nov 29, 2008 | 11:17 PM
wow is right. and as my brother was helping me bleed the ACD he said "dude you have like no gas" i was like whatever I will get it later. what messed me up was that the car started and ran and even drove a little bit. turned around parked it home and then it was intermitted. should have heard me filling it up from a gas can. sounded just like taking a **** after a hard night of drinking lol
Old Nov 29, 2008 | 11:23 PM
DIDYSIS's Avatar
LOL, wish everything was that easy to fix :-)
Old Nov 30, 2008 | 12:01 AM
justa4banger's Avatar
me too
vics(evo8)
13
Nov 16, 2011 01:57 PM
blackbichGSX
11
Aug 7, 2007 04:50 PM
Johnboy1065
11
Apr 3, 2007 07:48 PM
woodc
Jun 16, 2005 06:46 PM
ku7484
Sep 9, 2004 03:18 PM
