Clocking the turbo WTF?
There is a clamping ring(?) that secures the turbine housing to the center housing. Once you remove the clamp, then you need to be super careful when separating the turbine housing away from the center housing. The turbine housing being made of cast iron is extremely heavy. If you donīt have a good hold of it, itīll slip down and damage the turbine blades.
dwn4cause
Aug 16, 2009 09:21 AM
USP45
11
Jun 29, 2004 07:51 AM
