Upgrading Evo 9 trans to Evo 8 4th and 5th gearing
Old Dec 3, 2008 | 04:24 PM
  #31
aka.ralliart15's Avatar
Originally Posted by Jeff_Jeske
I would leave 5th gear alone.... you would have much better accelleration using the EVO 8 4th gear going into the EVO 9 5th gear as it would already be in its sweet spot.
The EVO 9 3rd gear is also a little too short and you could benefit from going with the EVO 8 3rd gear.
The ultimate tranny is EVO 9 ---- 1,2&5 with EVO 8 ---- 3&4.
I would not even consider the taller 5th gear or double sycros as there is no reason to bang 5th gear.
Nice, good info here man. I would really benefit from a evo 8 3rd gear since the track that's closest to me is an 1/8th mile, although i have never been to a 1/4 mile i'm sure the 4th would give me more top end.{thumbup**
P.S- only suggested the 5th gear for better mpg purposes because everytime im in the highway in 5th Im always around the 4K area and i'm sure less revs puts less stress into the car.
Old Dec 3, 2008 | 05:09 PM
  #32
diablo2184's Avatar
what about not for the track, regarding the 5th gear?
what about highway pulls?
Old Dec 3, 2008 | 05:52 PM
  #33
Jeff_Jeske's Avatar
The difference in top end is 10mph but you will have better acceleration with the 9 5th gear. If you are doing highway pulls to 160+ mph I really don't know what to say about that.
The difference between the evo 8 and evo 9 5th gears probably wont make a difference in mileage. Definitely not enough to justify the cost of the gear swap.
Old Dec 3, 2008 | 06:46 PM
  #34
RyuEvoIX's Avatar
Originally Posted by damstr
Really don't know...last time I went to the track they had me drive right through the waterbox so when I launched I spun all first and some of second gear and I hit the 8200 rev limiter in 4th @ 119 before crossing the beams.
So with a good launch I should be around mid 120's or more.
Then you will not need to shift into 5th gear at the track with your current setup with an 8200rpm rev limit. Another thing that will help you is using a slightly taller tire. I recommend the Nitto NT555R. It will give you an extra 2mph to play with in all gears as apposed to the stock tire size.
Old Dec 4, 2008 | 02:36 PM
  #35
damstr's Avatar
Right now I'm running 255 40 18 KDW's.
Old Dec 4, 2008 | 03:07 PM
  #36
RyuEvoIX's Avatar
That's 0.3inch larger diameter then 17's with 245/45 that I'm running. You should definitely NOT have to shift into 5th with your estimated trap speed range.
Old Jan 17, 2009 | 09:46 AM
  #37
damstr's Avatar
Just a little update...sending the trans back to shep this Tuesday and I've decided to just switch to the Evo 8 3rd and 4th and keep the Evo 9 5th in there. Also going to double synchro 5th gear so its more forgiving on hard 4-5 shifts.
If I did put the Evo 8 5th in there it would still bog so whats the point.
Old Dec 21, 2010 | 10:00 PM
  #38
kyoo's Avatar
So it's not worth it? I was going to switch from evo9 5th gear to evo8 gear to drop the rpms/noise/slightly improve the gas mileage in my car.. i do a TON of highway driving (mostly to get something done to the car lol)
Old Dec 22, 2010 | 07:19 PM
  #39
Jeff_Jeske's Avatar
I really don't think it will result in any measurable difference. Even the MR with an extra gear doesn't get any better mileage.
Old Dec 22, 2010 | 07:24 PM
  #40
kyoo's Avatar
More so I was looking for a drop in RPMs, but according to Shep the evo 8 5th gear will wear the synchros more than the evo 9 5th gear?
this was exactly what he said:
The difference internally (the amount of friction on the synchro) is much less with the Evo 9 5th, = less wear & tear on the synchro, thus longer life.
So, I guess I will stick with my buzzy evo 9 5th gear
Old Dec 23, 2010 | 06:16 AM
  #41
38six's Avatar
Yeah that's exactly right & plus your 5th gear will remain more usefull. I see alot of the road racing guys are even trying to get their hands on the shorter jdm 5th gear. So the evo 9 5th gear is probably the best option for the street...
MagicManRed
596
Dec 9, 2020 07:59 AM
fromWRXtoEVO
Apr 21, 2014 06:57 PM
LtownEvo
11
Aug 13, 2012 07:11 AM
strtrcng426
96
Feb 29, 2012 08:53 PM
W_evo8
11
May 27, 2009 07:59 AM
