FPRED vs CBRD BBK
Old Dec 8, 2008 | 08:09 PM
vaboostn33's Avatar
Originally Posted by Shacochis06
fpRed=35r type power
thats when you spend about 10k more in mods then you would for a 35r kit. Plain and simple. You wont make the same power with the fp red as a 35r unless you dump more money.
Old Dec 8, 2008 | 08:11 PM
bwesley82's Avatar
Originally Posted by Evo8Emperor
What does the bbk blue full go for ?? anyone have any idea?
https://www.evolutionm.net/forums/sh...d.php?t=379854
Old Dec 8, 2008 | 08:32 PM
Mautofied.IS300's Avatar
Originally Posted by bwesley82
My dyno chart is in the BBK dyno results thread and I made 398 whp and 350 wtq on CBRD's mustang dyno with identical spoolup to the stock turbo with the BBK Full.
I know CBRD's dyno reads quite low, what does that equate to on a typical dyno (dyno dynamics? can't think of name). I don't think those numbers stand out to people who don't know what type of dyno CBRD runs. Anything ~400whp+ @ CBRD is quite an accomplishment for that turbo.
Good work.
-Will
Old Dec 9, 2008 | 03:51 AM
6-speed's Avatar
i would love to see a 30r at 550hp....theres very few....the 30r is almost non exsitent anymore
What about the 50-trim kits that many Evo owners had?
Sadly as time goes there will always be innovations which result in equal (if not more power), more efficiency, and all at a cheaper cost to the consumer.
As stated previously we're seeing 50-trim and 30r power out of the FP Red at nearly half the cost.
Just look at all the huge developements in turbos available for the Evo within the past 1-2 years: CBRD BBK, FP RED, 35HTA, FS365, & HTA86.
It's a good time to be an Evo owner .
Old Dec 9, 2008 | 06:10 AM
EugeneSAN's Avatar
When spool up is come on RED on 93 octane?
Old Dec 9, 2008 | 06:17 AM
Import Junky's Avatar
I agree. I've never seen a high horsepower 30r
Old Dec 9, 2008 | 06:22 AM
brodienuchies's Avatar
The HTA versions are making 550whp range...not 600whp though.
Old Dec 9, 2008 | 07:36 AM
letMeIn's Avatar
you should ask yourself what are your plans for your car. Sure Red makes more HP but at what cost ?? If you drag race go with Red. If you road race and you don't want to be pushing 30psi + and you run pump gas than BBK is your answer.
Old Dec 9, 2008 | 07:48 AM
fugiwara's Avatar
Just type "bbk dyno" and "bbk available" in the search box, and you'll find 2 threads talks about the bbk turbo, I found all the answers I needed there, there is no need to start a thread like this.
Old Dec 9, 2008 | 07:59 AM
theshadow's Avatar
The two seem to be pretty similar given similar bolt ons on pump at similar boost levels.
I went for the BBK Lite and it's awesome - spools like stock but keeps pulling right up to redline. I imagine the Fp Red would be similar but perhaps with ever so slightly slower spool (most people probably wouldn't notice).
In this range (bolt ons + pump) I'd say that the BBK wins out - it's cheaper, spools insanely quick and offers just as much power.
When you go for more extreme setups however (meth, race gas, e85, bigger boost etc.) I think the FP Red has more potential in it the harder you push it - more room to grow.
I'm more into road racing so the BBK suited my needs better but the FP Red also deserves mucho respecta.
Bottom line, you can't really go wrong with either one...both have the potential to get you near the magic 400whp mark on pump. It's a great time to be an Evo owner with options like these to choose from.
Old Dec 9, 2008 | 12:34 PM
sparky's Avatar
Originally Posted by theshadow
The two seem to be pretty similar given similar bolt ons on pump at similar boost levels....I went for the BBK Lite and it's awesome - spools like stock but keeps pulling right up to redline. I imagine the Fp Red would be similar but....In this range (bolt ons + pump) I'd say that the BBK wins out - it's cheaper, spools insanely quick and offers just as much power....I'm more into road racing so the BBK suited my needs better but the FP Red also deserves mucho respecta....
There is a lot of generalizing going on when comparing the FP Red to the BBK. For example, an assumption is being made that the BBK turbo is better for road racing than the FP Red. Also, that the BBK pulls right up to redline. Are you implying then that the Red does not pull right up to redline?
Has it been irrefutably proven that the BBK produces more power on pump gas than the FP Red? If not, then why does everyone assume that the BBK is a better pump gas turbo? Offers just as much power....Then post up some back-to-back dyno plots please. The BBK wins out? Compared to what?
Old Dec 9, 2008 | 12:47 PM
Shacochis06's Avatar
^+1 i dont understand why people keep saying its not a pump gas turbo.....and as for as road racing just look at Nills..
https://www.evolutionm.net/forums/sh...378&highlight=
1st place....he has numerous road racing wins with the Red
Old Dec 9, 2008 | 02:06 PM
Cali2MDevo8's Avatar
Registered User
Love how all the fanboys come out. If your debating between these turbos:
1. Use the search button
2. Use the search button one more time (RESEARCH)
3. Find out what your needs are for your evo
4. Call CBRD or FP.
5. Talk to them ; )
Follow the simple list and you will be on your way to 400whp
Old Dec 9, 2008 | 02:13 PM
CBRD's Avatar
again,
talk to whoever is doing your build/tune.... talk to whoever you are considering and go from there.....
we have proven our turbo, fp has proven theirs... you need to determine what is the right fit for you.
cb
Old Dec 10, 2008 | 05:07 AM
hawa's Avatar
I'll be real honest. I bought my Green a couple years back and to me at that time, it seemed like the best choice.
Now, the CBRD BBK is out! If t had been available when I bought my Green, I probably would have opted for the BBK instead. Why? Because it would have probably suited my needs better. I wanted quick spool and run crappy 91 octane gasoline always.
The Green is great at boost levels over 26 PSI. But, on 91 octane I never see higher than 23 PSI max. Also, the Green spools a bit slow with the 10.5 hotside to suit my setup.
