Better Throttle Response FREE MOD
Old Dec 15, 2008 | 03:42 AM
DRAGHICI's Avatar
I loosened and moved the throttle tensioner about 1/4-1/2 inch toward the passenger side, then i tightened it at its new location.
this removed that little bit of slack from the throttle steel cable, now when i tap the gas peddle even just a small tap the needle moves, before you could feel the slack, now no more!
the best part is when taking off slow, also down shifting.
hope you guys understand what i did
Old Dec 15, 2008 | 06:03 AM
gsrboi80's Avatar
Gotta be careful with this though too tight and you actually going to be holding the throttle plate open a little at idle and especially on decel. Easily seen on the wideband and you gas millage will suffer.
Old Dec 15, 2008 | 06:17 AM
DRAGHICI's Avatar
Yes its very sensitive, the rpm is at 1000 when idle, before it was around 900-950.
Someone else try this? Because it works and feels like a better responding car.
Old Dec 15, 2008 | 08:23 AM
Appauldd's Avatar
This is a basic mod that many have done, to include myself. Simply taking out the slack in the thottle cable by adjusting the bracket on the intake manifold, it so easy.
Be careful though. I you push your gas pedal by hand you will see that it won't bottom out. there will be a little flex of the pedal shaft because the throttle body is fully open. To fix this pull off the plastic topper under the pedal and thread a bolt or two onto the mounting bolt. Then re-install the plastic stop. Then re-check to see if you are getting full throttle. Once this is done you have a positive feeling when you are at WOT.
Old Dec 15, 2008 | 11:41 AM
DRAGHICI's Avatar
You think that's necessary for just a little slack?
Old Dec 15, 2008 | 11:45 AM
Appauldd's Avatar
It isn't much movement and shoudn't hurt anything. I just like the feel of a positive full throttle stop.
Old Dec 15, 2008 | 02:35 PM
DRAGHICI's Avatar
I just want to say that my EVO feels like a new EVO
Old Dec 15, 2008 | 04:13 PM
Kracka's Avatar
Since when did adjusting the throttle cable become advanced? Good tip for people to go check (I just did mine a few weeks ago), but this belongs in General, not Advanced.
Old Dec 16, 2008 | 06:37 PM
Slo_crx1's Avatar
I agree, but like mentioned make sure there is *some* slack to the cable, you need a little bit of deflection to make sure the plate closes completely. It will also effect your off throttle deceleration if adjusted too tight, as I can vouch for personally...12.4afr under decel almost every time.
Old Dec 20, 2008 | 07:47 AM
awdboosted's Avatar
Slack is necessary in the throttle cable. If it's too tight it might keep the plate open.
Under Decl you should see the wide band go lean. 18.00 + AEM gauge reads nothing. Thats how you know the thottle plate is closed and the car is decl
Old Dec 22, 2008 | 12:09 AM
nightwalker's Avatar
It will also intermittently throw a TPS code.
Old Jan 25, 2009 | 09:39 PM
mchuang's Avatar
log it with evoscan and verify the voltage.
bbong
Jun 11, 2017 05:25 AM
rxtec
Mar 14, 2016 07:58 PM
2011MR_Lover
Mitsubishi TC-SST Discussion
May 24, 2011 02:17 AM
rraulston
19
Mar 25, 2006 03:28 PM
KevOVIII
18
Nov 10, 2005 08:05 AM
