View Poll Results: Rebuild Exedy Twin or Purchase *new* ACT MB7-HDSD?
EXEDY TWIN REBUILD
16
51.61%
ACT MB7-HDSD
15
48.39%
Voters: 31. You may not vote on this poll
REBUILD: Exedy for the 3rd time or ACT MB7-HDSD?
Old Dec 17, 2008 | 05:14 PM
legal-z's Avatar
sounds like there is an issue other than just the clutch discs. i have a exedy twin in my car and i drive it hard on the street. the clutch is still good after 20k+ miles at over 500whp. make sure there isn't something else causing it to fail.
Old Dec 17, 2008 | 05:29 PM
Evoryder's Avatar
Well what else? Pressure plate issues would be give symptoms like not disengaging. Car drives and shifts like butter but will slip at 4k rpm and catch at 5k. Typical symptoms.
The 2nd time around I don't think my mechanic resurfaced the flywheel. Also, the second set of discs could have been generic(not sure if there are such things), they weren't the same as the originals.
I managed 28k on the first clutch, 14k 2nd discs...i'm not sure I want to try and get another set of discs for another 14k of driving. Based on my maintanence calendar, new discs installed "56,133K(2/18/2008) EXEDY TWIN DISC" not even 1 year.
So far ACT is leading in my books and I know with my luck i'll need more than just discs when the mechanic takes off the transmission.
Just to add: Car has a new slave, new master cylinder, and SS lines.
I appreciate all inputs thus far.
Old Dec 17, 2008 | 06:28 PM
EmeryatSTM's Avatar
Try the act. You will like it
-Em
Old Dec 17, 2008 | 10:20 PM
Evoryder's Avatar
Em how much power you putting down on this clutch?
Old Dec 17, 2008 | 10:24 PM
ONRAILS's Avatar
i would say his car made well over 650whp.
Dude, get the ACT.
do it for the forum we need some more feedback on the clutch.
How much are the act twins?
Old Dec 18, 2008 | 02:15 AM
1NastyMR's Avatar
IF you have a Exedy twin disk why in the world would you buy a different clutch just rebuild and don't waste $ and if your looking to get a different clutch do a Quarter Master twin disk. I wouldn't do any type of ACT clutch on my car
Old Dec 18, 2008 | 02:42 PM
prockish_03evo's Avatar
Rebuild it but make sure you get a new pressure plate
Old Dec 18, 2008 | 02:46 PM
Bom's Evo's Avatar
I went ACT. You already know why it wears out soo fast. Just soo much friction in them twins for daily driving.
Old Dec 18, 2008 | 03:36 PM
JKD's Avatar
JKD
If I had a clutch fail on me 2 times, I would look towards a different direction. I vote ACT for that very reason.
Old Dec 18, 2008 | 05:24 PM
Evoryder's Avatar
I am going to be going with the ACT. Thanks for the input people, i'll hold on to the exedy pressue plate, and flywheel
Old Dec 20, 2008 | 06:44 AM
Tigre's Avatar
maybe you should try something new since the constant rebuilding of the exedy isnt getting you anywhere
Old Dec 21, 2008 | 06:35 PM
DesertEvolution's Avatar
Wow! By the looks of this thread, I'm going with the ACT.
Old Jan 7, 2009 | 05:00 PM
Evoryder's Avatar
bump due to an update.
My clutch has stopped slipping. I babied it for about 3weeks nothing more than 20% throttle. I turned off my meth and lowered the boost from 30 down to 24.5psi. Just looking for insight on why it would go from slipping to fine? Glazed disc?
Old Jan 7, 2009 | 07:08 PM
fimotorsports's Avatar
as I said before it may be your pressure plate, not the disks, had similar issue with mine before
Old Jan 7, 2009 | 07:11 PM
Evoryder's Avatar
Well when it dies in comes the ACT
Aby@MIL.SPEC
May 18, 2016 05:39 PM
pistons4550
Dec 31, 2014 08:28 PM
eitan
For Sale - Cars For Sale
27
Apr 21, 2014 10:30 AM
RS.Escort
May 27, 2013 11:29 AM
Blayq Owns You
Dec 2, 2009 06:59 PM
