Air Filter Shootout Test - Results!
Why are there so many people whiny about not seeing the stock airbox? Everytime someone conducts a test on their own dime and time people start whining "why didnt you test this why didnt you test that." I fyou dont like the test method or the products tested then man up and drop the money and time yourself for the testing.
Kracka and MAPerformance, thank you very much for the test it was very informative.
Thanks again for the test guys. I was dead set on ordering the Apexi intake, but I'm not so sure as of yet. Like I said in my previous post, I don't mind giving up some HP for some TRQ.
hey, just to correct, my Agency Power billet adapter is 4.5"
I have seen that in other tests as well but the simple addition of a Velocity Stack changed the way air entered the system and created more HP.
Granted, that was on V-8's but I would think the principle is the same. May act like a Venturi.
Doc
The proof is in the results; two filters beat out filterless, and filterless got 3 dyno pulls just like all the filters did. This goes to show a good air filter is very little restriction to the intake system and helps by smoothing out the airflow before it gets to the MAS.
I concur with the velocity stack concept. K&N does not incorporate this and this would also explain why the no filter test did worse than some of the filtered tests.
It's a dyno and not a lab. There are some variables out of our control and it's not a perfect representation of real world, on-road, conditions. However, everything we did was as closely controlled as possible and provides a pretty good unbiased power comparison amongst most of the popular filters for the Evo.
