oil temp gauge went crazy
Old Jan 8, 2009 | 06:52 PM
evolsam's Avatar
ok so i was stopped at a light and the temp gauge went up passed the H, it didnt go up slow. it went up in chunks. but as i started moving it went back to jus below half. it hasnt gone back up, dont smell anything nor see anything wrong...could it be be a loose/bad sensor?
Old Jan 8, 2009 | 07:09 PM
jmelocik's Avatar
Is it a Prosport gauge and sensor?
Josh
Old Jan 8, 2009 | 07:29 PM
SICK9's Avatar
exactly which guages are you talking about?
Is it the oem MR oil temp guage down by the radio?
Or is it the coolant temp guage in the speedo cluster, since you mentioned the H.
The one in the speedo cluster is the engine coolant temp guage not oil..
If it's this one, check your coolant level in the radiator and overflow tank when it cools off, "Dont open if it's Hot".
Please elaborate a little more on which guage you are referring to.
Old Jan 8, 2009 | 08:22 PM
evolsam's Avatar
hahaha my fault yea its the coolant on the speedo cluster, i had multiple threads opened. ill check tomorrow too dark right now, but y would it jump up to the H in neutral and go back and stay under half while running? it didnt go back up and i wasnt on a hill either
Old Jan 8, 2009 | 09:08 PM
apeximprt2nr's Avatar
i have a similar problem with my stock coolant gauge...it reads cold when cruising on the highway and right in the middle when street driving.
Old Jan 9, 2009 | 07:51 AM
andrewzaragoza's Avatar
if thats the case its probably the coolant fan. you should check if it turns on. just start the car and keep it on idle. keep it running probably around 5-10min. in that time the temps should be running on normal operating temps and that fan should be intermittently turn on and off to maintain the temps. the reason its not going up if you are cruising is because the wind hitting the radiator at cruising speed is enough to cool it most of all because the weather is cold right now.
Old Jan 9, 2009 | 09:01 AM
Jeff_Jeske's Avatar
If it went past the H that might indicate a problem but if it went back down before moving again that is normal.
When the car is cold check to see if your radiator is full and the fluid is clean.
Old Jan 9, 2009 | 12:01 PM
Ted B's Avatar
That is a classic indicator of a thermostat that is stuck open. The problem with that is it can drop coolant temp to a point whereby the ECU goes into 'warmup mode', which will significantly richen the fuel mixture (back to open loop) and that leads to all sorts of issues (reduced fuel economy being one of them).
Old Jan 10, 2009 | 06:48 PM
Evokid8's Avatar
i have the same issue, do i need a new coolant sensor or thermostat?
Old Jan 11, 2009 | 07:54 AM
Ted B's Avatar
If the coolant temperature gauge shows a significant drop in temp to the colder part of the gauge when on the freeway, change the thermostat.
Evo47
Jul 16, 2018 10:49 AM
88888
Apr 26, 2013 08:39 AM
InoNothingMR
Jul 16, 2012 09:30 PM
import111
Mar 10, 2012 06:52 AM
MTRJunior
65
Jun 15, 2010 02:09 PM
