o2 bung on midpipe ok to use for wideband?
Old Jan 16, 2009 | 12:38 AM
LakerRaider's Avatar
i know the most common place to in install a wideband is to put an o2 bung on the downpipe, but for some reason i have an o2 bung on my midpipe (hks carbon ti). Will this be ok to use with an AEM UEGO? or will the readings be inaccurate? what if i put it on the cat and put the factory o2 sensor on the midpipe?
thanks a lot for all input
Old Jan 16, 2009 | 06:46 AM
HighwayStarX's Avatar
readings will be inaccurate. Just stick with it on the downpipe at a 3 oclock angle.
Old Jan 16, 2009 | 09:29 AM
shadow1's Avatar
The Evo VIII factory O2 sensor went into the midpipe. That is why HKS put the bung there. For the IX's Mitsu moved the O2 sensor to the cat.
Old Jan 16, 2009 | 12:19 PM
Evolessfornow's Avatar
It should be fine in the mid pipe as long as you don't have a cat and any exhaust leaks before the WB sensor.
Old Jan 16, 2009 | 03:19 PM
damn i still have my stock cat on...
Old Jan 16, 2009 | 03:23 PM
shadow1's Avatar
The cat will lean out the WB readings so it won't be accurate. The ideal WB location is on the DP right before the cat to keep it away from the turbo heat. If you run a test pipe, then you can put the WB in the test pipe or in the midpipe.
Old Jan 16, 2009 | 09:27 PM
sho669's Avatar
The sensor in the cat on the IX is only a cat monitor, O2 is in the...02 housing sure they read the same thing but serve a different purpose. I would try to keep the sensor as close to the turbine outlet as you can, that way you get the most accurate reading.
Old Jan 16, 2009 | 09:43 PM
sikrsix's Avatar
The aem wideband sensor should be at least 18" away from the turbo and at a 2 O'clock (10 degrees) position.
Old Jan 17, 2009 | 11:13 AM
ttt
Old Jan 17, 2009 | 11:18 AM
TeStUdO's Avatar
Originally Posted by LakerRaider
ttt
It's been answered, no reason to bump your thread. Put the sensor on your downpipe. Follow sikrsix's instructions.
If you put the sensor any lower than 2 o'clock on the downpipe, condensation can collect on it and ruin it.
EGHBauce
Jul 6, 2008 09:08 PM
bboy_RES
Sep 21, 2007 09:31 PM
evod810
Aug 25, 2006 06:09 PM
Option2
May 24, 2006 08:20 PM
03redtype-s
Mar 2, 2006 09:10 AM
