Precision Turbo 6262 daily driver???
Old Jul 31, 2009 | 02:17 PM
  #76
norcalSRTrida's Avatar
oldd thread.
if OP wanted only 500-550...
optimum setup would be a twinscroll T4 35r. FATT powerband, fast spool up, and capable of 500 w/ ease.
next would be a HTA35... 59mm inducer (compared to 62mm of a 6262) w/ the ability/option to run a twinscroll.
Old Jul 31, 2009 | 06:19 PM
  #77
binh's Avatar
Originally Posted by crcain
This was a back to back test no other changes between 3582 and 6262?
disregard what i said about the spool up time between the two.
one plot was mph and the other dyno was rpm
Old Jul 31, 2009 | 06:49 PM
  #78
aka.ralliart15's Avatar
I've ridden on a 6262 daily driver(Cwill's) on E85 though(732whp)....I can't feel that much lag though...one second after he steps on that thing I just freak out and scream for my life.
Old Jul 31, 2009 | 06:52 PM
  #79
Sharkbite2000's Avatar
So much power not enough time for lag to settle in
Old Jul 31, 2009 | 11:25 PM
  #80
evovin's Avatar
I used to have a HTAT4Z/HTA37R.
I ran 7.1@99mph w Sunoco 116 octane @32psi on street tires(all season tires) (1/8 mile track)
Now I have PT6262 and Im running 7.1@101mph on 93 octane only @29-30psi still on street tires.(1/8 mile track)
This was on my single Walbro. When I got tuned my second pump(BR double pumper) wasn't working because I never primed it.(my fault)
Now both pumps are working I can't wait to get re-tune again.
Go with PT6262
Old Aug 1, 2009 | 07:51 AM
  #81
Exactly
Old Aug 1, 2009 | 08:28 AM
  #82
D420mac's Avatar
Yup I have 711 HP on mine it's sick fast!!!
Old Aug 1, 2009 | 09:55 AM
  #83
crcain's Avatar
Too bad there hasn't been a back to back test yet against the 35R.
Based on charts I've seen posted, I'm inclined to believe the 35R spools a bit earlier. Hard to say how much. And I'm not talking about HTA, just a normal 35r.
Old Aug 1, 2009 | 11:00 AM
  #84
dont see why it wouldnt...
a 1mm smaller compressor AND turbine wheel over the 6262, and a 7lb/min lower flow rate.
i understand the billet wheel makes a difference, but i dont think that much.
i <3 my 6262 though. top end pull is awesome. i'd be interested in seeing the 6261 (or aka 6282) in comparison to the 35r and 6262 tho.
Old Aug 1, 2009 | 08:53 PM
  #85
CoMoEvo's Avatar
garrett 3076
Old Nov 24, 2009 | 09:32 PM
  #86
luvnish's Avatar
Guys,
With new Precision options available such as the billet 5857 and 6057, do these fall into the OP's goal of 500-550awhp with T3 turbo?
I've seen on other forums where the 6057 makes upwards of 450awhp, and even 533whp on a VW:
533WHP VW 6057
I spoke to a Precision rep and they recommended the 5857 over the 6057 saying that the 5857 has a better designed wheel which would spool quicker and support as much max power as the 6057.
What's the new consensus?
Old Nov 25, 2009 | 10:00 AM
  #87
[I.R.A.]_FBi's Avatar
6057 would have a bigger turbine wheel for a bigger displacement engine to avoid compressor surge vs 5857?
Old Nov 25, 2009 | 11:05 AM
  #88
ScorpionT's Avatar
Originally Posted by luvnish
Guys,
I would take a 6262 and 5857 over a 6057.
They share the turbine wheel, and the 6057 has a larger compressor.
Old Nov 25, 2009 | 11:39 AM
  #89
oh ok
Old Nov 25, 2009 | 04:38 PM
  #90
luvnish's Avatar
Which would you go with for a 2.0L? I'm thinking 5857 for 2.0L, and 6262 for 2.3L.
Is there anything about the 6057 that would make it your last choice from the three turbo's?
