skunk2 TB?????
Old Feb 1, 2009 | 08:06 PM
dsm25psi's Avatar
skunk2 TB?????
Anybody got any results on the skunk2 TB for the evo?? It looks like a very piece plus its about $70 difference from ported old evo tb and its bigger in size too.
Old Feb 1, 2009 | 08:45 PM
Kracka's Avatar
Keep in mind you also won't need to send your stock core in. I have one and should have it dyno-tested by the end of this week. Watch the boards for my results!
Old Feb 1, 2009 | 08:48 PM
dsm25psi's Avatar
i want to buy one tomorrow, lol but let me know the results
Old Feb 3, 2009 | 09:22 PM
David24's Avatar
I'd like to know the outcome too!
Old Feb 3, 2009 | 09:28 PM
vroomevo's Avatar
just installed mine, not 100% true bolt on but it is very nice quality.
low end/mid range seems to improve quite abit...in terms of torque, feels like spools alot faster. now, almost back to stock(compared to evo green which i noticed slight lag with HKS intercooler) spool up.
will dyno soon, still tunning in for idle...
Old Feb 3, 2009 | 09:42 PM
sspaladin28's Avatar
Didn't you have to port the IM out to fit this?
Old Feb 4, 2009 | 06:45 AM
Davo's Avatar
care to explain a lil more please?
Old Feb 4, 2009 | 07:12 AM
KevinD's Avatar
i've got one here about to go on a car. it actually does measure 68mm and is a very nice peice. typical "65mm" throttle bodies which are stock ones bored out don't actually measure 65... mil.spec measured 64mm, and the RC engineering one measured 63mm. mil.spec was a ton nicer then the RC engineering one though. i'll know the porting that needs to be done to the intake manifold tomorrow.
Old Feb 4, 2009 | 07:35 AM
dsm25psi's Avatar
what did you have to do?
Old Feb 4, 2009 | 08:41 AM
EE's Avatar
EE
Got mine ported by PPI. 65mm all the way
Old Feb 4, 2009 | 09:31 AM
SilverBulletIX's Avatar
I'll be mounting mine to a magnus V5 IM and had a machine shop port match the reducer bracket to perfectly match the TB. Can't wait to get this installed.
Old Feb 4, 2009 | 09:33 AM
vroomevo's Avatar
i had to trim with dremel on the TPS. i would not go in. luckly, i had two throttle body with sensors, i broke the 1st TPS, forcing the TPS to the location, but second one, i took time and trimmed a bit and went it OK.
Old Feb 4, 2009 | 09:41 AM
Mine is at Milspec now along with a fresh stock intake manifold. I went over the IM with Aby and he is going to port the IM to match the TB gasket. Should have some results in a couple weeks since I will do back to back dyno runs of my setup with stock TB/IM v ported im/68mm skunk2 TB
Everything else will remian static
needsboost
Jun 1, 2015 01:49 PM
superkizuna
May 6, 2013 08:27 PM
stihlalive
Aug 14, 2012 07:50 PM
ilikeppie
Jan 28, 2010 10:36 PM
evovin
35
Aug 27, 2009 05:22 AM
