just did a compression test,questionable results?
Old Feb 9, 2009 | 11:37 PM
pjb00stin's Avatar
hey guys,
i just did a compression test on my VIII. It showed 165,170,170,170.Thing is,I was watching videos and reading up on it,and some people did the test with the throttle body at WOT.I didnt.My motor was warm,though.Do I need to perform it with the TB at WOT?Thanks!
pj
Old Feb 9, 2009 | 11:45 PM
Johnboy1065's Avatar
it would be more accurate if you were to do it with the TB open but to be honest it sounds like your compression is very good and I wouldnt even worry about it
Old Feb 9, 2009 | 11:50 PM
Evolution IVGSR's Avatar
Um never heard of doing that I just do it when its sitting cranking it over... But looks like you have a good motor tho man as long as all the cylinders are within 5 psi that good man Mine is all with in 5 psi and still feels good... my other Evo had a 100 psi difference when it was blown mine was 160, 90, 140, 60 thats a bad motor lol So its rebuild now and That one is all at 160 across the board I think your fine I would worry about doing it again they other way...
Old Feb 9, 2009 | 11:58 PM
pjb00stin's Avatar
thanks guys!!!!
WOW!!! 160 90 140 60?!!!!???? I'll probably run the test again with the TB open and see if what happens
Old Feb 10, 2009 | 07:17 AM
justa4banger's Avatar
you should still do it again just to make sure..but it sounds like a really healthy motor
Old Feb 10, 2009 | 12:38 PM
Redline-Z's Avatar
Veteran: Air Force
Agreed! Your numbers are perfect and well within the +/- standard of 10% I have always done a compression test with TB open, Either way I think the results might be the same?
mr2rr
10
Apr 22, 2015 11:05 AM
Colbyy
28
Jul 19, 2011 06:38 PM
AKEVOIX
Apr 27, 2009 06:41 PM
evilevovegas
17
Dec 5, 2005 07:14 PM
GOKOU
17
Apr 12, 2005 07:17 PM
