Crank angle sensor
Old Feb 13, 2009 | 04:44 PM
evo8nfs's Avatar
Crank angle sensor
Looking for some help on this one... my crank angle sensor went out on my 05 evo 8 ... replaced it.. it ran for about 10 min then died and threw the code again for the crank angle sensor.. it will crank but not fire what could the issue be?? any help would be great.
Old Feb 13, 2009 | 04:53 PM
Cyloc's Avatar
Have someone watch the crank as you push the clutch. See it the cranck moves in and out. If it moves you have problems.
Old Feb 13, 2009 | 06:55 PM
Knightracer's Avatar
Could it be your cam angle sensor? Since both have to sync for the ignition to fire.
Old Feb 14, 2009 | 12:05 AM
Torque07's Avatar
that's what i would check. usually when the cas goes bad you will be able to start it then when it gets hot it wont run at least that's what happened to mine.
Old Feb 14, 2009 | 05:10 AM
Ted B's Avatar
Anyone who has a problem with the cam sensor may want to consider something like this (see heat shield):
It's an inexpensive piece of insurance, and is especially useful if there is additional heat in the engine bay, as is the case with tubular manifolds.
xceler8rob
34
Jul 17, 2016 12:57 PM
poonpower
Jan 18, 2016 05:59 PM
whatever210
Oct 19, 2015 07:18 PM
OC
Jul 4, 2015 09:07 AM
EVO9MRNJ
32
Mar 5, 2015 05:09 AM
