First time clutch job.
Old Mar 3, 2009 | 12:11 PM
  #91
pjb00stin's Avatar
for the amsoil you bought,which goes into the transfercase,rear diff,and tranny? SG 75w-90 and the MT 75-90?thanks!
Old Mar 3, 2009 | 12:17 PM
  #92
Evoryder's Avatar
Originally Posted by 05EvoVIII
I dont really see the need for an aftermarket flywheel as of right now and i could use that 400 bucks towards sumthin else like my intercooler setup.
Yeah AMS wanted 200 to port my stock mani. i live 40min away from them and when they were at there old shop there prices wernt that bad but my god i can afford there stuff anymore!
what manifold? Intake or Exhaust? One by the firewall or the one by the turbo? One Connected to the throttle body or the one with a heat cover over it?
Old Mar 3, 2009 | 06:37 PM
  #93
turbodreamz21's Avatar
wont a 4 puck clutch be killer for the tranny? i wanted ot do a 6 puck and ppl were telling me to go a street disc
just wondering?
Old Mar 3, 2009 | 07:39 PM
  #94
justa4banger's Avatar
Yup^^
Old Mar 3, 2009 | 07:45 PM
  #95
05EvoVIII's Avatar
oops my bad man the exhaust mani thats is by the turbo with the heat cover on it
just wondering?
Evom did a write up on the 4puck that i bought and they said it drove better then the stock clutch and i have yet to find anything wrong with the fidanza 4puck as far as hear/say goes.
Old Mar 3, 2009 | 07:54 PM
  #96
mega-z's Avatar
This **** is so funny! I'm going to print this and put it on my refrigerator
[/QUOTE]
Old Mar 5, 2009 | 01:28 PM
  #97
05EvoVIII's Avatar
Update
Hey guys i got the clutch n flywheel out today. I droped the flywheel off and there going to resurface it for $40 and i also droped of the stock exhaust mani to another local shop and he is goingt to call me with a price after he takes a look at it for the port job.
Got some pics for ya guys
As i was postin the pics the shop called n said my flywheel is done so ima go pick it up now then get back to work.
Should i use locktight on the flywheel bolts or any other bolts???
Old Mar 5, 2009 | 01:36 PM
  #98
SPOOLEDTSiAWD's Avatar
I didn't and never had a problem. Just make sure everything is tourqued down to spec.
Old Mar 5, 2009 | 01:39 PM
  #99
yup^^
Old Mar 5, 2009 | 02:08 PM
  #100
RLLN247's Avatar
Hey Brandon. That is a major project you have taken on. I wish you luck with it.I think if i were 45 min. away from ams i would let them do it. Iam sure you will learn a lot.I have the white evo in town used to see your car at the car wash.Havent seen it in awhile I guess i know why.How do you get to ams so quick it takes me an 1 an half and iam only 10 min from bourbonnias.
Old Mar 5, 2009 | 02:40 PM
  #101
05EvoVIII's Avatar
Do i have to toruqe spec every bolt or just the clutch n flywheel bolts? And what should i use to clean the flywheel off?
HAHAHA i didnt say i did the speed limit on the way up there
Hows the evo runnin man? Shes a beaut!
Old Mar 5, 2009 | 02:46 PM
  #102
Mr. Evo IX's Avatar
Brake Cleaner for the flywheel / presure plate surface.
Probably should also torque your motormounts, steering rack bolts, tranny bolts, etc. everything unless you have a good arm gauge.
Old Mar 5, 2009 | 03:08 PM
  #103
05EvoVIII's Avatar
Yeah thats what i was thinkin i just wanted to make sure b4 i go sprayin it.
Ookayy thenn.. thanks dood
Old Mar 5, 2009 | 03:20 PM
  #104
05EvoVIII's Avatar
How does the tob retainer clip things work? like do i reuse the 2 that are on there?
Old Mar 5, 2009 | 03:25 PM
  #105
Evoryder's Avatar
definitely use red loctite on flywheel bolt and pressure plate. vibrations may cause it to get loose and fall out. Don't want to go back in just to tighten a bolt or if worse it will cause damage.
