top mount vs equal length vs cast manifolds
Old Feb 28, 2009 | 03:30 PM
  #31
BluEVOIX's Avatar
Originally Posted by JC evo1
off topic but whats being driven off the cam gears? ^
Probably belt driven pcv vacuum pump.
Old Mar 1, 2009 | 05:49 AM
  #32
eTiLiKo's Avatar
It can be a mechanical fuel pump
Old Mar 1, 2009 | 01:02 PM
  #33
E7R's Avatar
E7R
It is
Old Mar 1, 2009 | 02:09 PM
  #34
sprx19's Avatar
There are an awful lot of 1g dsm's running deep into the 9's with cast manifolds.
just my .02$
Old Mar 1, 2009 | 07:25 PM
  #35
a1091156's Avatar
Originally Posted by Ted B
That's exactly right. Cast iron absorbs it and retains it, and that makes it better. Ever wonder why tubular steel manifolds radiate so much more heat than a cast iron manifold? Radiated heat is wasted energy. This isn't my opinion. It's common knowledge. Think about it.
Lol, sorry Ted but you need to take a course on thermo dynamics. Check the thermal conductivity of air, cast iron, 304 and inconel 625. The thinner the walls, the less energy it needs to become saturated.
Also a true motorsport turbo exhuast manifold will have atleast another full length pipe around each of the primary tubes forming an insulation 'air gap' such that it retains the radiated heat.
Old Mar 6, 2009 | 11:00 PM
  #36
BerserkerX's Avatar
What about 13-8 stainless for manifolds? that is extremely durable and its a lot less than inconel.
Great read though. Oh one question though on a manifold that is all over the place aka full-race. How do you put a heat shield on that??
Old Mar 7, 2009 | 07:14 AM
  #37
Ted B's Avatar
Actually, "thermodynamics" is one word, and nowhere did I indicate that thinner walls (less mass) requires more energy to saturate. But that is less about thermodynamics and more about calorimetry, don't ya think?
The stainless commonly used for race-grade applications is 321, which has greater heat stability as a result of its titanium content. It's more expensive than common 304, but it's more durable and lasts longer.
Old Mar 7, 2009 | 04:48 PM
  #38
BerserkerX's Avatar
Are high carbon steels like 1026 or 1018 manifolds good for manifolds? They are fairly cheap and it seems fairly durable. How is it for heat saturation?
But sticking to the actual topic of this thread. would the type of manifold depend on the turbo being open or twin scroll?
Old Mar 10, 2009 | 01:47 PM
  #39
JKav's Avatar
Carbon steel does not have nearly the oxidation resistance, strength at temp, or creep rupture strength to be suitable for a turbo manifold. Stay far away.
ETS Michael
EvoX 'For Sale' External Engine / Power
20
Sep 10, 2009 03:54 PM
MrJdmJimi
11
Apr 29, 2008 07:09 PM
Geoff Raicer
11
Feb 23, 2006 12:04 PM
Randman
14
Sep 29, 2005 11:11 PM
