Intake mani cleaner
Old Feb 26, 2009 | 06:47 AM
ElectricEvoIX's Avatar
Intake mani cleaner
hey looking to find something to get all that carbon build up off the inside of the intake manifold. Has anyone used or know or anything that's good enough to spray into the manifold with it off the car that can get that gunk out? Thanks
Old Feb 26, 2009 | 07:17 AM
jdmeg6's Avatar
why dont you take it off and spray that puppy out with brake clean that should get any residue out of the manifold good luck man. why is the intake manifold dirty it should be pretty clean inside from all my experience unless maybe the turbo has a oil leak or is it dirty because of the recirculating blow off valve? any way good luck cleaning your manifold the break clean should make her nice and shiny for you
Old Feb 26, 2009 | 07:20 AM
apagan01's Avatar
This stuff is alot better than contaminating your seals and sensors TPS, ect...
just got a shipment this week.
one can is good to clean twice, and it will clean your TB and intake mani
Safely blasts away gum and varnish from throttle plate and throttle plate shaft
Improves air flow for smoother idling
Helps restore fuel economy
Safe for oxygen sensors and catalytic converters
Old Feb 26, 2009 | 07:21 AM
apagan01's Avatar
chek out this thread
https://www.evolutionm.net/forums/ve...m-cleaner.html
let us know if we can help.
15 bucks for a can shipped to any of the lower states
Old Feb 26, 2009 | 12:45 PM
apagan01's Avatar
thanks for your PM, glad we could help.
Old Feb 26, 2009 | 02:10 PM
justboosted02's Avatar
i used carb cleaner, $2/can
Old Feb 26, 2009 | 04:21 PM
Kracka's Avatar
The manifolds get dirty from the EGR valves that recirculate exhaust gasses back into the intake manifold.
Old Feb 26, 2009 | 04:47 PM
Smike's Avatar
I have used a BG cleaner (looks like and IV bag) in the past and there is also SeaFoam (easier to get - any autoparts store). You can run it though the intake via a vac line - does the same thing as the BG product. It will clear off the carbon build up.
WARNING: do this in the driveway and let it all blow through. It will make your car become a fog machine. I also like to do it before I change my oil. The SeaFoam is oil safe, but I have made it a ever 20k oil change thing.
Old Mar 3, 2009 | 08:09 PM
Drift4's Avatar
better plug the ports for the ISC motor, after the throttle plate, or you'll damage the ISC motor
Old Mar 3, 2009 | 08:12 PM
Drift4's Avatar
This is what I use. Sensor safe especially for the ISC motor. BG ISC® Induction System Cleaner™ http://www.bgprod.com/products/fuelair.html
Old Mar 3, 2009 | 08:32 PM
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
Wynn's is the bomb! This stuff WORKS!!!!! Andy, come to Cali buddy!
Blue Evo 8
21
Dec 6, 2016 01:06 PM
Jaysaevo8
Apr 5, 2016 01:06 PM
EvoIXMR
14
Jul 12, 2008 05:55 PM
levo2nr
12
May 25, 2006 05:49 AM
ozBanana
Lancer Engine Tech
Apr 20, 2003 01:24 AM
