Buschar strokers use oil?
Old Mar 11, 2009 | 01:47 PM
Ant1's Avatar
I have a 1000 mile old Bushar 2.3 block installed at the minute. It's 18 months old but only covered 1k from new. Is it normal to use excessive oil? About 1litre every 500 miles?
Old Mar 11, 2009 | 01:50 PM
scorke's Avatar
Most I have seen use some...
You're only a couple hundred miles past being properly broken in.
Scorke
Old Mar 11, 2009 | 02:01 PM
Craig King's Avatar
Buschar eh?
I wonder what Buschur has to say about another company with a similiar name selling 2.3 strokers as well.
BTW - check here: https://www.evolutionm.net/forums/ev...e-out-oil.html
Old Mar 11, 2009 | 02:19 PM
Ant1's Avatar
Over here in the UK fellas engines built by leading tuners do not use oil. Even Evos running over 800bhp!!!
Old Mar 11, 2009 | 02:31 PM
scorke's Avatar
Well then did you just feel like paying for shipping charges or what?
Scorke
Old Mar 11, 2009 | 02:35 PM
EvoDan2004's Avatar
Originally Posted by Craig King
Buschar eh?
give some slack man. you understand what the guy meant. he is from across the pond. no need to be a smart ***.
Old Mar 11, 2009 | 02:43 PM
URBANRCR's Avatar
It is normal for a new engine to use oil but it should be broken in by now. A car will use oil for three reasons bad rings , bad seals , or leaking oil . things may have not properly seated. Pull the spark plugs out of it and see what they look like.
Old Mar 11, 2009 | 03:11 PM
Ant1's Avatar
It's ok i'm used to the usual idiots on here
I did not buy the engine from the US, the previous owner did. Very long story so i won't bother you all with the details. Will check out the rings or seals. Is this a engie out job to replace if required?
Old Mar 11, 2009 | 03:44 PM
URBANRCR's Avatar
for the rings yes for the valve seal you dont have to remove the head. If you look at your spark plugs and you have a crusty build up on it then that would be your valves or piston rings.
Voltexed
Jan 29, 2017 08:27 PM
TxFAkuma
Nov 3, 2015 01:04 AM
Svendiesel
Nov 30, 2009 12:06 AM
melon07
Oct 11, 2008 09:54 PM
wickdaddy
Lancer How Tos / Installations
Nov 9, 2006 10:31 AM
