Fp Green turbine housing size?
Old Mar 13, 2009, 02:36 AM
LION evo's Avatar
I have a problem with the turbine housing of my fp green. The turbocharger does not spool up. The trouble is in the wastegate of the turbine housing. It was milled by previous owner and now it leaks. I need new turbine housing. Is Fp green turbine housing the same with evo 9 turbine housing? Will Evo 9 turbine housing fit without fabrication?
thank you for replies
Old Mar 13, 2009, 04:48 AM
sparky's Avatar
You probably won't be able to find a used Green turbine housing by itself. The Green uses a larger turbine wheel than the stock IX turbine wheel, so, no, a stock turbine housing from a IX turbo will not fit. Forced Performance ''cuts'' the stock housing internally so that the larger diameter turbine wheel from the Green will fit. Thus, I think that your best bet would be to call Forced Performance, and they'll sell you a new Green turbine housing.
Old Mar 13, 2009, 05:36 AM
LION evo's Avatar
The thing is that I live in Ukraine that is Eastern Europe and it will take a month or more to get it from Forced performance.
The seller from Ukraine turned to be a cheater, he refused to refund the money or fix the turbocharger.
Do you have any ideas how to fix broken wastegate ?
Mauricio Evo IV
11
Oct 31, 2017 12:10 AM
bsbllfit7
24
Mar 5, 2016 07:58 AM
Hołek
12
Jan 30, 2014 02:39 PM
Brigganator
Feb 28, 2013 05:28 PM
midegade
15
Mar 9, 2011 06:45 PM
Quick Reply: Fp Green turbine housing size?
