the EXHAUST thread
Old Jan 6, 2004 | 06:21 PM
  #226
e8's Avatar
e8
Originally posted by Kayaalp
Hi David,
What about the Magnaflow version? Does that also exit stright out? Also, is it 3" all the way back to the cat or does it neck down somewhere?
I'm planning on keeping the stock cat for now, but I'll probably upgrade to a high-flow cat in the future. I'd like a 3" system from the cat back.
Emre
And how does the magnaflow compare to the JDM muffler in sound?
Old Jan 7, 2004 | 07:18 AM
  #227
David Buschur's Avatar
The Magnaflow is an optional muffler only. The style of the exhaust, standard or JDM is what makes the difference on how the muffler comes out in the rear.
IF you order a catback only there is no way to NOT put a reducer in the system. There are some other BS dealers claiming they don't use a reducer in the system for their catbacks but they must think you guys are ignorant. They are getting away with it by butt welding a 2.5" flange to the end, well the flange ends up being the reducer. We use a tapered piece of tubing to make the transition from the stock cat to the 3" cat back pipe. This can be changed in the future to go with a full 3" system.
David Buschur
www.buschurracing.com
Old Jan 7, 2004 | 10:13 AM
  #228
Kayaalp's Avatar
Originally posted by davidbuschur
If you order a catback only there is no way to NOT put a reducer in the system...We use a tapered piece of tubing to make the transition from the stock cat to the 3" cat back pipe. This can be changed in the future to go with a full 3" system.
David,
Thanks for your honest and intelligent reply! I think I'd like to get the 3" system w/ Magnaflow for now. I'd like to avoid warranty headaches for now as the car is still only a month old and may need servicing before long. It's nice to know I can upgrade to a high-flow cat and downpipe for a full 3 inch system without having to toss out a perfectly good cat-back system.
Emre
Old Jan 7, 2004 | 11:15 AM
  #229
That's great. When you order the downpipe and such later make sure to remind us you have our catback. We will have to send you a special offroad/highflow cat that is a little longer.
Something else you might want to consider while you are waiting on your warranty to expire is the 2.5" downpipe and muffler delete we have on sale now. These two are $360 and will eliminate the two worste parts of the EVO exhaust system. Believe it or not the muffler delete pipe with the stock cat is quieter than our 3" catback. The HP gain will be higher with these two parts than with just the 3" catback in your case too.
David Buschur
Old Jan 7, 2004 | 12:23 PM
  #230
e8's Avatar
e8
are there any 3" high flow cats on the market that are CARB exempt?
Old Jan 7, 2004 | 12:45 PM
  #231
nmyeti's Avatar
David Buschur
A custom built 3 inch flange will allow you to bolt a 3 inch pipe up to the back of the factory cat. There are NO reducers in OUR system. The factory cat outlet is smaller then our cat back inlet. This allows you to use a 3 inch system with the factory cat for now, but still have options in the future. I sure hope we are not one of the “BS” dealers to which you were referring.
-Nathan
www.turboxs.com
Old Jan 7, 2004 | 12:59 PM
  #232
Eric Lyublinsky's Avatar
-Nathan
www.turboxs.com
yes I can confirm this. I'm using TXS's 3in cat back. It's 3in tip to tall at the very least.
Eric
Old Jan 7, 2004 | 01:40 PM
  #233
mikesevo8's Avatar
I have read this entire thread and searched, but have not found my answer ( or I missed it ) so here goes ....
I want to get the HKS DP and the Hi-power CB, along with a 3" UR high flow cat. ( Yea, I know it's not full 3" )
From what I have read in this thread, am I to assume that both HKS DP and cat back neck down where
they bolt to the stock cat ???
If so, it sounds like getting the 3" cat is pointless...
Old Jan 7, 2004 | 01:43 PM
  #234
The HKS downpipe does not neck down. It's 2.76 all the way. Getting a 3in cat is not pointless because it's one less restriction in the exhaust system.
Eric
Old Jan 7, 2004 | 01:48 PM
  #235
mikesevo8's Avatar
Eric
Thanks. Do you ( or anyone else ) know about the flange size on the catback ???
If it's 2 1/2", then this connection to the 3" cat may be a problem.
Also, on catbacks where a flange with a 2 1/2" hole is welded to a 3" pipe, couldn't you just enlarge
the hole with a grinder ??? Or do you also have issues with the bolt holes lining up ???
Old Jan 7, 2004 | 06:34 PM
  #236
Alfriedesq's Avatar
My car has a 2.67 " down pipe - HKS - and as you know it makes decent power - its plenty if your under 400 whp
Old Jan 8, 2004 | 01:28 AM
  #237
e8's Avatar
e8
-Nathan
www.turboxs.com
How much is your cat back and will it bold up to the stock cat?
Old Jan 8, 2004 | 10:44 AM
  #238
mikesevo8's Avatar
Bump on my question about the HKS Hi-power catback a few posts back.
My future desired exhaust is HKS DP to UR 3" cat to HKS hi-power catback...
DP to cat, no problem --> 2.75" to 3" ...
Does the catback ( which is claimed 3" ) reduce to 2.5" to bolt to the stock cat ???
Will this become a choke point when I switch to a UR 3" cat ???
Old Jan 8, 2004 | 10:45 AM
  #239
598 yes
Old Jan 8, 2004 | 10:46 AM
  #240
yes does tapper yes it will chock but only when you reach 400+ hp.
Eric
