the EXHAUST thread
Old Dec 6, 2005 | 08:14 PM
  #706
alloyic_rs's Avatar
Originally Posted by davidbuschur
alloyic rs,
I agree, if you are planning on doing our full 3" turbo back don't waste the $300 on the axle back/offroad pipe now.
The axle back/offroad pipe is a good gain in power and the noise level is still not too loud as the factory catback tubing has a couple of resonators in it. It is actually more restrictive than the factory cat!
David Buschur
www.buschurracing.com
Wow I guess I can scratch the idea of axle back/test pipe. Makes me wonna rip out my stock pipes right now!
I'm looking forward to getting one of your catback or turboback systems.
Thanx David.
Old Dec 7, 2005 | 07:48 AM
  #707
David Buschur's Avatar
I can do a custom JDM style tip for someone that HAS to have it. I do not want to put this into production again but winter is slow here and I can use my car for a fixture to build them and get the perfect.
The flamed tip look we won't do as the SS doesn't blue up very good.
David Buschur
Old Dec 7, 2005 | 07:56 AM
  #708
The 3" exhausts are clearly listed and described on our site. If you order just a 3" catback it comes with no flange as we assume you will slip fit it to what you are building or have. The SCCA catback comes with the 3" flange on it already. Sorry it was confused.
David Buschur
Old Dec 7, 2005 | 09:27 AM
  #709
Rastmp's Avatar
Question
David,
I bought a slip on by a mistake (turbo back). And I had to buy a 3 inch flange from you. Question? With a slip fit, in order to weld the flange, do I have to cut the pipe tip off so that the length is accurate? This is the end that connects to the cat.
Thanks
David Buschur
Old Dec 7, 2005 | 12:55 PM
  #710
EvoIXMR's Avatar
David Buschur
Your site says the following:
"This version of our 3" EVO8 catback exhaust will allow you to run the factory converter. Although we recommend running our 3" downpipe and 3" high flow cat or offroad pipe, we realize that some of you need a system to run certain SCCA classes, etc. You will need (1) 3" exhaust clamps with this system, offered separately. We recommend our stainless wrap clamps as they will not crimp the pipe and give a positive seal preventing any leakage."
Does the suggested 3" exhaust clamp help attach the muffler to the midpipe? Also, I get the part that the SCCA catback will bolt to a stock cat - So, does the exhaust taper and have a smaller flange OR does the stock cat have a 3" flange?
Does the SCCA exhaust use a different muffler?
Thanks!
Old Dec 7, 2005 | 01:06 PM
  #711
ries's Avatar
Originally Posted by jmmairborne
I Have a DC Sports downpipe and catback ,after 1 hour driving my service engine soon light came up.
do a mechanical O2 fix, Ive run the same setup for a while now and havent thrown a CEL using the mech O2 fix
here's the link on the how to:
mechanical O2 fix
hope this helps you out
Chris
where in NC are you?? I can help you out if your not too far, but its pretty easy and you should have no problems.
Old Dec 7, 2005 | 01:22 PM
  #712
shadow1's Avatar
Thanks!
Its a full 3" flange. It still bolts up and seals against the smaller OEM cat flange.
The clamp is mandatory to seal the mid pipe to the muffler. They sell the Walker clamp. Mine leaked. I threw it out and bought the Jegs clamp which is a better design.
The SCCA has the same muffler options as the standard catback - loud Buschur race muffler or quieter Maganflow muffler.
Old Dec 8, 2005 | 06:27 AM
  #713
The SCCA catback has a full 3" flange on it that still seals up well to the factory cat.
BTW, I went and read the website and it is not very clear. We just changed it. I apologize for any inconvienence it caused any of you!!
The SCCA catback can be ordered with either muffler we offer.
David Buschur
Old Dec 8, 2005 | 06:32 AM
  #714
EvoIXMR's Avatar
David Buschur
David - Not to beat a dead horse - The way I understand it - The only differnce between the SCCA cat-back and the "regular" cat-back is the addition of the flange at the cat end of the mid-pipe, correct?
Old Dec 12, 2005 | 10:10 AM
  #715
C6C6CH3vo's Avatar
How much HP do I have locked up in my stock catback? I will be in the CB market soon once I can get the $.
Mods (04, 93 octane):
MBC
3" DP and cat delete (with stock catback)
10.5 Hotside (waiting for downtime to install)
272/264 cams
HKS RS intake
Fuel pump
DF street tuned
Car is slightly slower than it should be with the respective mods and I think it's the factory catback. I recently tapered the CB where the 3" catdelete mates to to it and also saftey wired the muffler's flapper wide open which helped boost response, but was wondering if the stock CB is locking any more HP and how much.
Old Dec 12, 2005 | 10:47 AM
  #716
Yes, an SCCA catback has a flange on it.
The combo of parts you have, c6c6,is pretty extreme to still be running through the stock exhaust. I'd say that our catback alone is going to add a solid 20+ whp in this particular situation. You need one bad.
David Buschur
Old Dec 12, 2005 | 12:39 PM
  #717
C6C6CH3vo's Avatar
Thanks
I guess I better pull the cork and get a catback, I'd get the $450 Buschur but my darn catdelete has a flange.
Old Dec 12, 2005 | 07:59 PM
  #718
fire-ballz's Avatar
david,
will you have another christmas sale on your turbo back exhaust systems as you did in the beginning of this long thread??
Old Dec 12, 2005 | 10:42 PM
  #719
vanisher's Avatar
Originally Posted by fire-ballz
david,
Old Dec 13, 2005 | 10:58 AM
  #720
OUR CATBACK if you order the SCCA catback has a flange that will bolt to the stock cat or anyone's offroad pipe.
David Buschur
