AMS Oil Pan?
Old Mar 20, 2009 | 08:11 PM
peter*g's Avatar
AMS Oil Pan?
Anyone in this group have an AMS Oil Pan? I am having numerous problems making it work on my car and want to talk to someone who has one on their car (or someone in the know who is not the shop doing my install or AMS).
Thanks.
Old Mar 20, 2009 | 08:18 PM
jid2's Avatar
These guys and some in this thread are working with it on some issues.
https://www.evolutionm.net/forums/ev...oday-pics.html
Old Mar 20, 2009 | 08:33 PM
nothere's Avatar
Peter, I had English Racing install my pan. Aside from the (stock) turbo oil line not being a direct fit I wasn't aware of any major issues on the install. You might ask them for any difficulties they may have had.
Old Mar 20, 2009 | 08:36 PM
jid2's Avatar
^^^ I didn't know that was part of the led dome light upgrade - nice.
Old Mar 20, 2009 | 08:41 PM
smack_evo's Avatar
hey peter, we were just fitting mine over at gst the other day.
the pan hits the rear main bolts on arp hardware so it needs a little clearancing and the scrapper also needs a bit of trimming if you're running a longer stroke(at least for a 100mm) to clear the rod bolts.
edit: i just read your post in that other pan thread. we haven't got my motor up and running yet so i can say much about the leaking issue but without the clearancing for the main bolts it did keep the flange from mating up true to the block.
Old Mar 20, 2009 | 09:35 PM
peter*g's Avatar
Where are they located?
Old Mar 20, 2009 | 09:37 PM
peter*g's Avatar
Interesting. I'm wondering if the bolts are the issue and the mechanic is just not seeing it. I'll have them check tomorrow.
My plan is to be at Sears on Sunday with you guys, if the freakin' car ever gets put back together...
Old Mar 21, 2009 | 06:39 AM
nothere's Avatar
John Bradley and English Racing are both here on the forum. Should be able to PM them. Or, Englishracing has a web site too.
Geographically they are close to Portland Oregon.
Old Mar 23, 2009 | 09:35 AM
peter*g's Avatar
So, quick update here. We did get it installed without leaks, but it took some pretty serious work. This is definitely not a DYI install:
  • We found 6 points of interference keeping the pan from sitting flush with the block. 2 points were the APR hardware we used on the bottom end, so that's not a huge surprise. The other 4 points were the cradle. We had to grind down the thickness of the welds on parts of the pan to make it fit.
  • The pan itself was slightly warped from welding. None of the edges were truly flat (as checked on a proper straight edge). Why Moroso doesn't deck these things (like you do to a head) after they're assembled is beyond me.
  • We used lots of the Mitsubishi bond and let it sit overnight to give it the optimal curing time. The excess bond is not great (some of it may make it's way inside the pan, although we did our best to avoid it), but it will work.
Ran it on track yesterday and no leaks so far. Overall, this part is not a high point in my experience with AMS. I have been ecstatic about every other part I bought from them (intercooler, oil cooler, rear mustache bar eliminator, and lots more), but this part requires a ton of work to make right. Just my $0.02 -- Moroso should make it right for them, or AMS should find another supplier.
Thanks to everyone for advice and input on this one
Old Mar 23, 2009 | 01:05 PM
Don evo5's Avatar
For the money its costs should be spot on but
with anything custom its usually not
nice looking pan tho
snowpro4g63
Nov 29, 2016 09:57 AM
David Buschur
83
May 27, 2016 07:39 AM
evo1008
Apr 13, 2016 07:05 AM
gallas
11
Jan 8, 2009 03:41 PM
plokivos
10
Nov 3, 2004 01:57 PM
