REAR Quaife LSD
Old Mar 22, 2009 | 08:04 PM
Nomad4g63's Avatar
REAR Quaife LSD
Does anybody have it? What are the advantages of it?
This is the only 1 i have found
http://enjukuracing.com/quaife-mitsu...ar-p-7561.html
I'm thinking of upgrading my OPEN LSD which comes stock on the 03' Evo 8 and putting a much stronger LSD, that will reduce my wheel spin off the line. My only concern is will my axles handle the grip?
Old Mar 22, 2009 | 08:12 PM
Jeff_Jeske's Avatar
You can get a ralliart or RS front LSD for your 03 for $400. That is what you need. The rear diff already have a LSD.
Old Mar 22, 2009 | 08:24 PM
Nomad4g63's Avatar
Ok um im going with a Shep T-case with Quaife front LSD already. Thats why i didn't ask about front. But i have open rear diff.
Old Mar 22, 2009 | 08:27 PM
Jeff_Jeske's Avatar
All evo's came from the factory with an LSD in the rear.
The xfer case contains the front diff. Then the front to rear split is managed via viscous coupler and some other fancy diff in the tranny.
Old Mar 22, 2009 | 08:31 PM
tripperfx3's Avatar
I gotta ask. It says your drive a IX. The IX's had a front diff I believe. Or did you buy an VIII as well?
Old Mar 22, 2009 | 08:47 PM
Jeff_Jeske's Avatar
I had an 03 EVO 8 that I replaced the front open diff with a ralliart LSD from TRE.
I have since moved on to an EVO 9 which has ACD and the front LSD right from the factory.
Old Mar 22, 2009 | 08:50 PM
Nomad4g63's Avatar
Okay either way! With the amount of power im putting down i dont care if Arnold Schwarzenger came stock with an Evo 8 LSD front or read, its not strong enough to hold the power.
I'm looking for QUAIFE LSD, REAR. I need something stronger. I've heard of people putting the Quaife in the front but not the rear.
Im asking about the 03 Evo 8
Old Mar 22, 2009 | 09:10 PM
Jeff_Jeske's Avatar
That's probably because even the big boyz with 9 second evos are still running the stock rear diff. They have a bigger problem with axles than diffs. You should pull the rear diff and flip flop the plates so they lock up harder and faster. TRE posted a how-to.
Old Apr 8, 2009 | 01:53 PM
projectpsi's Avatar
To answer your question Quaife does not make a rear dif. Only Front and Center.
Old Apr 8, 2009 | 02:08 PM
Ev0ikon's Avatar
Stock Rear Diff has been in 8 sec so you shouldn't worry about that... unless you have too much money and looking for some headache.
jansoft_16
Jul 3, 2016 09:16 AM
kazx9r
Sep 6, 2013 09:04 PM
EVOXMonroe
17
Mar 25, 2009 09:23 AM
06ravenmr
Sep 12, 2008 11:31 PM
funnyclub
Apr 24, 2007 03:10 PM
