Transfer Case Advice...
Old Mar 25, 2009 | 09:33 PM
blownevo's Avatar
Hey guys, I'm changing my clutch on my 05 Evo GSR and the guys working on it mentioned that my transfer case needed ATF SP3 or something.
I really don't know. But what type of fluid is that? I know it's automatic tranny fluid, but is the info accurate as far as that being what I need to put in the transfer case? Also, why do I need to put that, there's a reason they said, I just forgot what it was. Something about differential control. Also can I buy it at any autoparts store, or does it have to be at Mitsu?
HELP!!!
Old Mar 25, 2009 | 10:01 PM
MitsuEvo05's Avatar
i had the same problem and i just went to the mitsu dealer and it was cheap and easy. it only cost about 8 dollars and just ask for the a/t fluid or ATF SP3
Old Mar 25, 2009 | 10:07 PM
cableguy5752's Avatar
The ATF 3 is for the ACD fluid (reservoir under the hood behind driver side headlight). I cant remember what fluid goes in the transfer case itself. Maybe Mitsu Diaqueen or equivalent. A simple search should answer your questions.
Old Mar 25, 2009 | 10:15 PM
blownevo's Avatar
K thanks guys.
Old Mar 26, 2009 | 02:34 AM
lilevil's Avatar
that's one of the few things that u better off just buying from the dealer, no shipping and you are guarantee to be buying the right stuff, just go to the Mitsu dealer to get those maintenance fluids for your car.
Old Mar 26, 2009 | 07:51 AM
Nasty Evolution's Avatar
You need to use Diaqueen LSD gear oil in your TC and rear diff. It's about $40 a gallon. holds .58 quarts.
http://www.jscspeed.com/evo/clutch/diaqueen.htm
Old Mar 26, 2009 | 10:09 AM
blownevo's Avatar
Ok i know I need ATF SP3 for the ACD, but will 75 90W in ROYAL PURPLE work for everything else?
Old Mar 26, 2009 | 10:16 AM
apagan01's Avatar
get what mitsu recomends for the ACD it is a very sensitive system.
now for the TC an rear diff, Severe gear 75w90
Old Mar 26, 2009 | 10:53 AM
Wallesasuaz's Avatar
Stick to STOCK fluids.
yenny
Aug 23, 2012 08:03 PM
RawrImAMonster
27
Jul 3, 2012 07:25 AM
EvoIIIAj
Sep 30, 2011 04:25 PM
CooleyKing
May 18, 2010 01:00 AM
Denverwhitetrac
Feb 27, 2007 09:10 AM
