Twinscroll 35R or HTA35R
Originally Posted by dsevo
If thats the case why aren't we seeing any TS HTA86 combinations?
I'll let you know in a few weeks with a Full Race TS T4 manifold setup coupled with a HTA86 using a Garrett 1.00 TS housing.
It's at the thermal coater now.
the single scroll HTA82 was at 20psi at 4400rpm. i have no dyno numbers because where i am there is no dyno. I have 1200cc injectors at 80% duty cycle with AFR of 11.5 using Q16 gas with 38-39psi boost. Anyone will have a rough idea of how many HP that would be?
What was your injector duty at before and after the swap in the meat of the powerband? Do you think you are making more power up top?
injectors duty cycle was at 71% and now i am at 80% with 38-39psi. The wastegates opens at that point so i was told to get the backup springs for them so i can raise the boost to about 42psi. On the HTA82 i was running 35psi
ETS Michael
EvoX 'For Sale' External Engine / Power
16
May 19, 2013 06:00 PM
ETS Michael
86
Jan 8, 2013 02:48 PM
