Injector size limitations with EcuFlash?
Old Apr 1, 2009 | 02:54 PM
AWD_Terror's Avatar
Just curious if because ECU flash runs off the stock ECU if there are any injector size restrictions?
Im not looking for huge injectors to be honest, but Im curious if I should just skip 780's and go to 880's to be able to make use of the power my Green can make.
Any idle issues or drivability issues over something like a 680cc?
Old Apr 1, 2009 | 03:11 PM
GST Motorsports's Avatar
680's are fine, people run 1400-1600
Old Apr 1, 2009 | 03:14 PM
Steve93Talon's Avatar
I went with FIC 950s, plenty of room to grow, drives exactly like it did on the stock injectors after about 1/2 hour of dialing them in.
Old Apr 1, 2009 | 03:18 PM
Ooops double post. :-/
Old Apr 1, 2009 | 03:31 PM
kkarim's Avatar
1000cc rc's running like stock
Old Apr 1, 2009 | 04:14 PM
AWD_Terror's Avatar
I know 680's are fine. I run them. lol. I want more power that I dont think they will support though.
Anyone know how much power 780's are good for? Or if I should just jump to 880's.
I was thinking 1k's if I can get a steal on them, but I really dont need anything that big. Dont plan on E85 as I dont even think I can get it around me easily.
But over 1k cc idles fine on the stock ECU? Man times have changed. lol
Anyone touch or heard anything about the Injector Dynamics injectors yet? My tuner swears by them now.
Old Apr 1, 2009 | 05:55 PM
kkarim's Avatar
It really depends on how well they are scaled..
Concerning the power capacity, it depends on your target afrs...
At 11.5 AFR with a bsfc of .75, the maxed out stockers should be enough for 42 lbs of air.
680's will be enough for up to 51 lbs
780's will be enough for up to 59 lbs
780's will be enough for up to 66 lbs
A rough rule is 1lb of air = 9~11 bhp.
This is obviously the capacity of a maxed out injector. Now you take this number and multiply it by the highest duty cycle you find acceptable.
These are just some quick & rough calculation, so don't take my word for them... :P
Old Apr 1, 2009 | 06:13 PM
justa4banger's Avatar
i run 1000cc and it feels like stock
Old Apr 1, 2009 | 06:48 PM
JohnBradley's Avatar
1000s are pretty easy, I have run as large as 1680s but only succesfully on E85. I think the new style FIC BlueMax injectors will probably work in the larger sizes but I have yet to test them on a stock ECU.
Old Apr 1, 2009 | 09:27 PM
Redline06's Avatar
can anyone vouch for 1200cc PTE injectors on stock ECU?
evo-kro
E85 / Ethanol
Nov 18, 2017 06:13 PM
Ferp
May 8, 2016 12:41 AM
Creamo3
Apr 25, 2009 01:13 AM
popadel
Jul 22, 2007 11:30 PM
Ted B
May 19, 2006 10:29 AM
