Ticking Noise coming from engine
Old Apr 4, 2009 | 10:28 AM
evo unknown's Avatar
I have this noticably loud ticking noise coming from the engine. I hear the noise best when I am in 3rd or 4th lightly cruising. When I give about 25-50% throttle I hear this ticking noise as the boost builds from just below 0 just just above zero, then can't be heard. Then when I let off the gas, it ticks again while the boost drops? I thought this was normal, but it's gotten a little louder over a short time.
I believe it might be the lifters? But can someone explain the exact job the lifters do and why this would go bad after 38k miles? What do you think?
Old Apr 4, 2009 | 10:47 AM
BenJ's Avatar
It could be lifters, however it could also be your injectors. Have you done anything with your injectors? Even the stock injectors are known to have a slight "tick" to them. The exact job of the lifter is to follow the lobe of the camshaft to open/close your valves.
Old Apr 4, 2009 | 11:36 AM
No i have not done anything with my injectors? I know the evos have loud injectors that tick, but i don't believe this is them. Thanks for input.
I just don't know why these would start to act up like this at low mileage.
YzBrad99's Avatar
Do you have any modifications?
Old Apr 4, 2009 | 12:44 PM
rolly1818's Avatar
Registered User
could be the 3 port.
Old Apr 4, 2009 | 01:08 PM
No modifications, bone stock.
What's the 3 port?
Old Apr 4, 2009 | 01:09 PM
Like the boost solenoid? I also thought of that, but the noise has gotten louder over the past few months.
Old Apr 4, 2009 | 08:08 PM
lemmonhead's Avatar
boost leak
Old Apr 4, 2009 | 08:12 PM
Majuljo's Avatar
whens the last time you change your oil?
Old Apr 5, 2009 | 08:58 AM
no boost leak.
actually just changed my oil the other day and it still happens. what would that have to do with it?
Old Apr 5, 2009 | 03:25 PM
bump
Old Apr 5, 2009 | 03:33 PM
EVOLVEU's Avatar
are you the 1st owner of your car?
Old Apr 5, 2009 | 03:44 PM
90GSX-03EVO's Avatar
It's the BCS. Quite common.
Hassan
103
Aug 5, 2023 11:37 AM
boostin gsr
Nov 27, 2015 01:34 PM
kyracer1989
Dec 31, 2012 12:43 PM
bstiffler582
Aug 1, 2010 08:24 PM
Sakamara
12
Mar 1, 2010 04:04 PM
