Evo cutting out.
Old Apr 5, 2009 | 01:43 PM
chase311's Avatar
Evo cutting out.
So I installed a new clutch and after putting everything back together, the clutch is working great. Now when I step on the gas hard somewhere between 3-4k RPM the engine starts cutting out and the car chokes and jerks violently, almost as if the engine is being starved and is not getting enough gas. But, I'm not sure that is the case. The plugs all look good and are gapped to .026. Anyone ever have a problem like this?
By the way, my car is stock. 44k miles.
Old Apr 5, 2009 | 04:01 PM
G20's Avatar
G20
can you do datalogging? my friend had a similar problem and it turned out he installed the mbc holes incorrectly. Also too much gas will cause hesitating as well.
Old Apr 5, 2009 | 06:44 PM
DarkScooby's Avatar
Mines doing the same thing, do you have an aftermarket fuel pump? I know you sayed your stock just wondering.
Old Apr 5, 2009 | 07:05 PM
N3VO's Avatar
this happened when my licp came off. stepping on it the car shook like crazy, maybe you have a leak somewhere.
Old Apr 5, 2009 | 09:20 PM
C130flyer's Avatar
+1 checka da boost pipas
Old Apr 5, 2009 | 10:07 PM
dancarroll0283's Avatar
Boost leak
Old Apr 5, 2009 | 10:51 PM
chase311's Avatar
Stock fuel pump.
I'll have to do a boost leak test. Thanks for the responses guys.
Old Apr 6, 2009 | 05:06 PM
chase311's Avatar
No boost leak. Any other ideas? It starts cutting out between 3-4k in every gear and refuses to make power or continue towards redline.
Old Apr 6, 2009 | 08:23 PM
chase311's Avatar
If I stay on the gas pedal lightly it will rev all the way to redline.
Old Apr 6, 2009 | 10:39 PM
chase311's Avatar
Possibly a bad fuel injector?
Old Apr 6, 2009 | 11:02 PM
G20's Avatar
G20
If it "hits the wall" then it's overboost hence fuel cut. If it's hesitating and jerking then maybe too rich. If it's too lean your car will hesitate but in a different way, it's like running out of fuel hence the car slowly slow down (I been in a lean evo before, not my evo so). How much boost?
Old Apr 6, 2009 | 11:13 PM
chase311's Avatar
Completely stock. Other than the new clutch.
Old Apr 16, 2009 | 08:04 PM
chase311's Avatar
Anyone else have any thoughts on this. I feel like I've exhausted every attempt at a fix. Boost leak test, new plugs, gone through the engine thouroughly an I'm at a bit of a loss.... Thanks!
Old Apr 17, 2009 | 06:36 PM
chase311's Avatar
Could this have anything to do with the MAF?
Old Apr 17, 2009 | 07:51 PM
03EVOGUY's Avatar
i have the same problem when i shift from 2-3 at 3k 3-4 at 3,500 it hesitates bad. an feels like the car slows down for a bit then picks back up again, an its really annoying. but when i first start to drive it in the morning it shifts and drives fine. i think it just needs a tune. mods-walbro 255,272 cams,bigger intercooler/pipes bigger air intake,stock injectors/block. any one have any ideas??
evoviiihan
10
Oct 22, 2016 10:00 PM
Syrihl
11
Feb 4, 2012 02:32 PM
BoosTyEVO
Oct 4, 2011 12:28 PM
jmmasellas
Lancer Engine Tech
Mar 31, 2011 02:39 AM
Arithmetic
Aug 25, 2006 01:07 AM
