Need some help with gaskets!
Old Apr 20, 2009 | 10:39 AM
coolguyuno1's Avatar
Question Need some help with gaskets!
I have a Greddy TI-C 3 inch exhaust, RSR catless dp 3 inch, and meagan o2 housing. What I was wonder is what I would need in order to replace all the stock gaskets I have and where to get them? Could I just get OEM all the way o2 gasket/donut gasket? How many will I need of each?
Thanks in advance,
-Chris
Old Apr 20, 2009 | 01:10 PM
evokid511's Avatar
when i did my exhaust i used all the factory gaskets again with no problems i also used the donut gasket on the o2 housing again just carved it out a lil to make it fit over the new o2 housing... why would you want to get new gaskets if the stockers are fine?
Old Apr 20, 2009 | 01:34 PM
Everyone tells me this is what needs to be done! They say I will have exhaust leaks if I do not!
Old Apr 20, 2009 | 01:37 PM
evokid511's Avatar
ooo i dont have any exhaust leaks, i was told by my tuner to use the stock o2 housing gasket or else it will leak eventually... your exhaust didnt come with new gaskets?
Old Apr 20, 2009 | 04:25 PM
biggie5252's Avatar
Pretty sure the stock gaskets are only 2 1/2 inch or whatever the stock exhaust is. Get some three inch gaskets. They should have come with your exhaust if you got it new. Or you should be able to get them at any import performance shop.
Stock donut gasket is fine unless you really f it up when you do the swap. I've never replaced mine.
Old Apr 20, 2009 | 05:03 PM
evokid511's Avatar
whoaaaaa i completely had a brain-fart when i posted earlier haha yeah you cant use the stock gaskets cuz the size haha my exhaust came with new gaskets i just reused the donut gasket my bad
Old Apr 20, 2009 | 07:04 PM
I bought then used, so would any 3 inch donut gaskets work? Stock o2 gasket should be fine for meagan o2 right?
Old Apr 20, 2009 | 08:20 PM
biggie5252's Avatar
Yes stock o2 housing gasket is fine.
Old Apr 20, 2009 | 08:25 PM
sparky's Avatar
Definitely, stay strictly with the stock Mitsu donut and O2 gaskets. Don't mess with that shiny, cheap aftermarket junk. Been there, done that! Just reuse your original ones.
Old Apr 21, 2009 | 11:25 AM
Ok, will do! Thanks guys!
konstantinosIX
Feb 10, 2011 07:34 AM
17579EVO9MR
13
Oct 26, 2010 12:53 PM
evolotion357
Apr 22, 2010 09:02 PM
Blizzackk
Sep 21, 2008 10:13 AM
ries
Aug 22, 2006 06:07 AM
