Thoughts on 2.0l long rod
Old Apr 21, 2009 | 01:21 PM
jamie_v1's Avatar
I am in the process of rebuilding my engine i did have a 2.3 stroker running a 35r which i was more than happy with
Today i was talking to a engine builder and he mentioned a 2.0l long rod using stroker pistons and 156mm rods on a 2.0l crank
Is anybody running this spec and what are they like the car is mostly used as a road car and what would be the advantages and disadvantages over a 2.3
Old Apr 21, 2009 | 01:34 PM
CNano8's Avatar
im pretty sure long rod motors can rev higher than a built 2.0 in general, like 10-11k rpm. DTMotorsports builds a 2.0 long motor.
Old Apr 21, 2009 | 01:55 PM
ScorpionT's Avatar
Magnus uses 156 and 162mm rods, apparently they work great for high revs.
Old Apr 21, 2009 | 11:15 PM
jamie_v1's Avatar
Thanks for the comments guys any more comments welcome
Old Apr 22, 2009 | 07:37 AM
Ted B's Avatar
Using a nominally longer rod (e.g. 156mm) does not increase the safe, usable rpm range in this context. The difference between a 150 and 156mm rod is only 4%, which is minimal. Piston speed, which is the largest determining factor in bottom end durability with respect to rpm, is unaffected by changes in rod length.
I have a long rod 2.0 presently, which uses a 156mm rod and 2.3 stroker piston. I did it because I prefer the slightly longer rod ratio and shorter piston. I wouldn't bend over backward to follow suit.
Old Apr 23, 2009 | 02:16 AM
jamie_v1's Avatar
Thanks for your input Ted i think i am going to stick with a stroker as it seems more suited to the purpose i use the car for
My03evo
17
Jan 6, 2017 10:36 AM
jnassar89
Aug 2, 2016 06:24 PM
TURBO_S2K
23
Oct 25, 2012 01:39 PM
Evolved_6
16
Sep 6, 2009 05:31 AM
Strm Trpr
16
Aug 10, 2009 07:32 AM
