Boost leak test and trange results...
Old May 3, 2009 | 04:06 PM
  #46
TTP Engineering's Avatar
Originally Posted by R/TErnie
If you need that much flow to find a leak YOU'RE DOING IT WRONG.
Having sufficient flow on tap allows one to fix leaks while the leaks still exist. You have 0-35psi on tap that will not take 10 minutes to build up those pressures.
I've been doing boost leak tests for 14 years.
Old May 3, 2009 | 04:12 PM
  #47
dan l's Avatar
Four ****ing pages dedicated to doing a boost leak test. I'm in awe, ****ing sad.
Old May 3, 2009 | 04:21 PM
  #48
dxbtune's Avatar
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
^ it took 4 pages to understand why air was getting into the oil system bud... knowing the reason behind it and getting input from professionals makes me feel a whole lot better... after all that's what this forum is for...
dxbtune
Old May 3, 2009 | 05:39 PM
  #49
dxbtune's Avatar
http://dtl.unimelb.edu.au/view/actio...e&usePid2=true
PG 5
Old May 3, 2009 | 10:20 PM
  #50
R/TErnie's Avatar
What I'm saying is... if you can't find a leak that needs more air volume than a schrader valve supports, then you don't need an air leak tester to find that you didn't put a coupler back on. Either that or you need to turn down your radio. It takes a matter of seconds (2-3) to pressurize the whole system through a schrader valve... so don't tell me it takes too long.
The length of which you do something doesn't correlate to the correctness of how you did it.
Old May 4, 2009 | 01:45 AM
  #51
Fast_Freddie's Avatar
Veteran: Navy
Uh... the ole schrader valve works quite well and can pressuirze the system in a few seconds, and this as at 25 psi... If you have a leak its not rocket science, nor should it take 10 minutes trying to figure out where the leaks coming from.... why try to over engineer it...
Tom no problem buddy, let me know if you need anything else okay!
Old Jun 21, 2009 | 09:33 PM
  #52
NsinEvo8's Avatar
So is this normal op? am having this issue with stock turbo, i hear gurgling in crankcase, while oil cap is off. I pressure test the whole system. am gonna eliminate turbo, and pressurize at ic inlet tomm..
Old Oct 11, 2009 | 07:42 AM
  #53
dxbtune's Avatar
^so, what did you find?
car runs strong no white smoke nothing, been 5 months now, no burning oil more than normal.
GT series turbo design I'm almost damn sure of it.
Old Oct 11, 2009 | 08:16 AM
  #54
cmj's Avatar
cmj
Same for me, the tire valve works great. A few seconds of compressed air and I'm up to 20-25psi on my boost guage.
ottoman
20
Oct 12, 2011 06:00 AM
dxbtune
11
Oct 18, 2009 04:32 PM
dxbtune
Apr 29, 2009 11:18 AM
dxbtune
55
Jun 6, 2008 01:50 PM
dxbtune
Mar 30, 2007 02:05 PM
