What bolt size to plug up O2 bung?
Old May 2, 2009 | 01:04 AM
INEVOIX's Avatar
I just installed my TBE and the only problem I've had is getting the rear O2 sensor out.
I've torched around it.....wouldn't budge.
Soaking with PB Blaster now.
I'm going to take it to a shop tomorrow and let them get it out....or try to...lol
If it gets destroyed, What size bolt would fit in the bung to block it off?
So far I've searched 10 pages and nothing. Maybe I'm searching the wrong words.
Thanks.
Old May 2, 2009 | 01:22 AM
Spinitch's Avatar
Get a Bosch replacement 02 sensor.
Old May 2, 2009 | 08:15 AM
INEVOIX's Avatar
Thanks for the reply but nobody has one in stock....not even mitsu.
It would be a 3 days to a week and I'm going out of town on Monday.
I'm assuming (please correct me if I'm wrong) that since our cars will run fine with a CEL when using a straight pipe, that unplugging it and capping off the bung (until a sensor comes in) will give the same CEL and I can drive the car.
Please correct me if I'm wrong. If not. Anyone know a bolt size to cap it off until a new sensor can be located.
Thanks
Old May 2, 2009 | 09:48 AM
Wicked E's Avatar
Do you have an Ace Hardware store near you? If so, they carry the o2 sensor bung back in the bolts/nuts section.
-E
Old May 2, 2009 | 09:56 AM
kanyonkid's Avatar
Thanks
that is correct... i had to take mine to a shop to take it out also lol...but u can get a bung at any auto store
Old May 2, 2009 | 09:57 AM
kanyonkid's Avatar
^^^i meant bung bolt cap thing
Old May 2, 2009 | 10:01 AM
Jersey Dino's Avatar
I am not certain of the exact size but it is the same as a common size transmission drain bolt. many autoparts stores should have them stocked
Old May 2, 2009 | 12:00 PM
INEVOIX's Avatar
Thanks for all the replies.
I found a plug for the hole
I can't imagine paying $200 + for the rear O2.
I bought a universal O2 sensor that crosses to a 99 turbo eclipse, for $59 I believe.
I just now need to figure out what the wires are.
Black= heater wires
Blue=
White=
One is the signal and the other is the ground.
Anyone know for sure?
Old May 2, 2009 | 12:03 PM
INEVOIX's Avatar
edit........made mistake on this post
Still looking for diagram
Old May 2, 2009 | 02:15 PM
INEVOIX's Avatar
Found what I needed and got the Bosch universal O2 sensor all wired up.
Works perfectly now with no CELs
Like I mentioned above, I believe the O2 sensor was around $50 - $60, which is much cheaper than the direct replacement.
If you're looking to replace your after cat O2, I would suggest this method and save a ton of money.
Thanks again to everyone who replied
evostang
Evo X How Tos / Installations
33
May 16, 2019 03:22 PM
BlkRVR5spd
Outlander Sport
21
May 4, 2015 07:38 AM
eboru-shon_x
18
Dec 31, 2010 01:56 PM
LIL EVOL
Apr 3, 2007 10:32 AM
Option2
May 24, 2006 08:20 PM
