Oil light flickers on and off at idle?
Old May 28, 2009 | 06:01 AM
GinNBoost's Avatar
Has anyone ever had this happen to them before? This morning on my way to work I noticed that when my car was idling (at a red light, in traffic, etc.), the oil light was flickering on and off. Now I do have bigger cams and sometimes the idle gets rough and during those "rough patches" that's when the light would be going crazy.
Anyone know the cause of this? I checked my oil level, and that was fine. Is it a bad sensor? Is it the bigger cams? I mean I've had my cams for almost a year now and this is the first time this has happened...Help please!
Old May 28, 2009 | 06:14 AM
ForcedFedRS's Avatar
Many times it is corrosion on the sensor connection or the sensor is out of range. Sensor is fairly cheap to replace. If you replace it, be sure to put some di-electric grease on the the connection to prevent it from happening again.
Old May 28, 2009 | 06:31 AM
GinNBoost's Avatar
Thanks for the help. Where exactly is the sensor located? And is it something simple to replace?
Old May 28, 2009 | 06:38 AM
rcheung's Avatar
Its located by the oil filter and it is very easy to replace.
Old May 28, 2009 | 06:42 AM
LI Pinky's Avatar
Same thing happened to my friend...Replaced the sensor and it was fixed...
G/L
Old May 28, 2009 | 07:04 AM
BBoostin's Avatar
Same thing happened to me last week.! Talked to jason at synaptic3 and he blessed me with his knowledge
Old May 28, 2009 | 07:09 AM
awddyno's Avatar
It's actually under the intake manifold, back of the block
Old May 28, 2009 | 07:13 AM
mdsevo06's Avatar
^That's the Knock Sensor.
Old May 28, 2009 | 07:19 AM
GinNBoost's Avatar
Great, thanks for the help guys.
Old May 28, 2009 | 07:28 AM
Smike's Avatar
Its on the back of the block. Easy fix I have replaced mine 2x now (115k) seems to last 60k then die out.
Old May 28, 2009 | 07:38 AM
andrewzaragoza's Avatar
https://www.evolutionm.net/forums/ev...d-problem.html
here is the url from another thread abt this. it also has the part # in there as well.
Old May 28, 2009 | 07:59 AM
GinNBoost's Avatar
But my car only has 20,XXX miles on it! That's why I'm a little surprised that the sensor is going out already...
Old May 28, 2009 | 01:38 PM
heel2toe's Avatar
If the sensor is corroded it really doesnt matter how many miles you have. Oxidation occurs even when the car isnt being driven.
Old May 28, 2009 | 03:31 PM
Joshs EVO's Avatar
My oil light flickered and come to find out is was cause I spun a bearing.
CaptainSquirts
Jul 5, 2016 07:43 PM
Pitside
Mar 5, 2014 12:43 AM
EvoHead7
11
Mar 7, 2012 03:56 PM
Ralliartize It
21
Feb 14, 2011 11:23 AM
jhkim45
Aug 27, 2010 07:21 AM
