oil light flickering...
Old Aug 25, 2010 | 10:57 PM
jhkim45's Avatar
just got an oil change today and the car is running absolutly perfect, there is nothing wrong with it, idle is perfect it pulls just fine, but when im crusing at about 50+ miles the oil light starts to flicker, the car is still running fine its just the oil light flickers, and when i slow down it stops flicker....anyone have any idea of what it could be??
Old Aug 25, 2010 | 11:13 PM
Marroccowned's Avatar
did you check the oil level?
Old Aug 25, 2010 | 11:18 PM
shrtstuff89's Avatar
assuming you used the correct oil...check it after the engine has been running, just allow maybe 5 minutes for the oil to drain back to the sump before checking - that's plenty, warm oil flows freely. Oh, and make sure the car's level.
Old Aug 25, 2010 | 11:24 PM
javicracer's Avatar
check your oil level, also if your car is stalling or dropping the rpm below 900 rpm it will make the light come off.
Old Aug 25, 2010 | 11:30 PM
jhkim45's Avatar
im idleing fine.....and i think it might be because of im using too thin of oil??? the shop i went to today didnt use 10w-30...and since im in az maybe the oil is getting to thin???
Old Aug 26, 2010 | 04:46 AM
Gibles's Avatar
Old Aug 26, 2010 | 05:30 AM
ekizenbe's Avatar
I just had this problem!!!! Go to a local parts store and tell them you need an oil pressure sender for your car. It cost less than 8 bucks. Its located on the back of your block under the intake manifold. It is round and has ridges around the body. Easy as pie to to change. You don't even have to drain the oil out of the engine. When you remove the sensor a very little amount of oil will come from the hole. thank me later! :-) good luck!
Old Aug 26, 2010 | 05:48 AM
BLKEVO9's Avatar
i also had this problem a while back but on the 8 its located on the back of the block and on the 9 its located by the oil filter. its a very easy and cheap part to change.
Old Aug 26, 2010 | 06:09 AM
EvoVIIIFL's Avatar
Oil light flickering is a idiot light... if its flashing pull over stop the car check the oil level... 1st and foremost. My sensor has 104K on it and no issues what so ever. I check my oil every day just to be safe regardless.
Old Aug 26, 2010 | 04:51 PM
DJAfterShok's Avatar
Either...
A) Your oil is low
B) Oil presure sender unit if f*cked.
Like the guy above me stated, its an idiot proof light. You should of pulled over and checked it out right away. What if it was something serious? there goes 3,500 for a new block!
Old Aug 26, 2010 | 06:11 PM
M_lizar's Avatar
Do you know how to check your oil level? Cause common sense tells me that would be the first thing to check.
Old Aug 26, 2010 | 06:13 PM
wizzo 8's Avatar
I had this problem at 20k miles. I replaced the oil pressure sensor and its all good now. I would still check your oil level
Old Aug 26, 2010 | 08:48 PM
1d10t's Avatar
Check oil level. Then go back to the place where you got your oil service. If it didnt do it before, and does it now, I'd complain and make them fix it
Old Aug 27, 2010 | 05:47 AM
wizzo 8's Avatar
Unless the oil is actually low you can't blame the oil change place for a sensor going bad. The oil pressure sensor is about $15. Just replace it and be done with it.
Old Aug 27, 2010 | 07:21 AM
EvoVIIIFL's Avatar
what did they use? they did put synthetic right? if they put the usual BULK oil **** you might be heading for a problem.. bulk oil is recycled oil and typically from what I've seen in FL its 5W30...
Thats why I do all my own oil changes... now that my motors built I run 20w50 non synthetic shell oil per Buschur. No issues and stuff is worth its weight in gold.. reason being I can run so thick is b/c winter here isn't cold enough to warrant going thinner.. best part is $35 gets me 12qts
DanielM
Jul 13, 2016 01:15 PM
CaptainSquirts
Jul 5, 2016 07:43 PM
DevilDuck
10
May 23, 2010 03:35 PM
spyonu2007
Oct 3, 2008 05:54 AM
t-dotlancer
Lancer Troubleshooting
Feb 14, 2005 08:33 PM
