Wierd clunk
Old May 28, 2009 | 07:56 PM
xmaciek82x's Avatar
Wierd clunk
Hello everyone,
This is kinda hard to explain, and not sure if anyone will know what I'm talking about. But yesterday I had a new suspension installed (HIGHLY doubt this has anything to do with it). I started noticing a "clunking" sound when I turn the car off, right before the engine completely stops. I tried to see where its comming from and can't really tell, just that it is around the engine bay.
It sounds like the engine litterly just died after I turn the car off.
Did I just never hear this sound before or what \
Car drives fine and everything, just when started to notice some extra noises when the engine is cold in the morning and when I turn the car off
Old May 28, 2009 | 08:49 PM
quick silver 8's Avatar
what kind of clutch do you have, ever since i installed my act clutch i noticed a similar sound. i was told it was my TOB. try turning off the car with the clutch pedal depressed and see if u still have the sound
Old May 29, 2009 | 06:07 AM
Lumpskie's Avatar
Also check the clearances on your downpipe. Mine used to rattle when I turned my car off.
Old May 29, 2009 | 06:53 AM
xmaciek82x's Avatar
I'm on a stock clutch. The stock TOB is not the greatest and has been making noises since the car was brand new. I tried what you suggested and the noise is still kinda there. The weird thing is, it mostly happen if the car is cold and I move it in or out of the garage. If I drive it for couple miles the clunking does really happen.
The downpipe sits on the bottom bracket (or whatever those two bars are called), but its wraped so I don't think and clunking would happen. I will check it out next time I'm under the car though.
Old May 29, 2009 | 08:55 AM
Jeff1121's Avatar
When i put springs on my car it caused it to clunk whenever i turned the wheel and was going slowly, say going into a parking space. It is possible your springs are setting.
Old May 29, 2009 | 05:55 PM
EatSleepBoost's Avatar
use a few washers on those tie bars to space em out so they are not touching your downpipe. when you motor flexes so does ur down pipe and you should not have anything restricting that movement besides if you had changed ur motor mounts. thats probably not ur noise though.
Firebat
11
Apr 19, 2016 01:43 AM
ninjacoco
Lancer Troubleshooting
Oct 19, 2011 06:24 PM
Enjoi926
29
May 18, 2010 05:11 AM
Dr.Sound
Feb 2, 2007 04:50 PM
evo72man
Sep 21, 2006 11:15 PM
