Wierd oil light
Old Jun 9, 2009 | 10:04 PM
EvoAlex48's Avatar
Wierd oil light
FINALLLYY got my baby back, but there is something wierd going on. I get an oil light when the clutch is in/ car is idling, but when ths driving the light isn't on.
is this a switch or is my oil pump dieing?
Old Jun 9, 2009 | 10:06 PM
MitsoKid's Avatar
had the same problem.. led to turbo failure.. my oil light would flicker sometimes when i stopped, well one day was taking a turn and there was a pop and then a whining noise... the bearings failed check your oil frequently! lol
Old Jun 9, 2009 | 10:09 PM
DIDYSIS's Avatar
My light flickers every now and again, I dont really know if it means anything, but I know its full of oil and never leaks a drop, Im interested to see what people say, maybe I am doomed, hope not, and its been plenty of miles not to
Old Jun 9, 2009 | 10:12 PM
EvoAlex48's Avatar
yeah i filled mine and it only gave me the light when its idling, i think its gotta do with pressure not level....idk =[
Old Jun 9, 2009 | 10:16 PM
DIDYSIS's Avatar
BUMP does it have to do with pressure?? Maybe thats a problem I need to find, even though since the last time I took my car apart it has not done it again so far. I am going to keep watching this one, thanks
Old Jun 9, 2009 | 11:20 PM
NWM_Tech's Avatar
It's either low pressure or a sludged oil pressure sender.
How many miles and is the engine clean or dirty inside?
Old Jun 10, 2009 | 12:52 AM
EvoAlex48's Avatar
17,000 miles on the engine, engine was just put in, very clean
Old Jun 10, 2009 | 05:36 AM
20gmr's Avatar
do your self a favor and get an oil pressure gauge in the car. It is an oil PRESSURE light. Try running a slightly thicker oil to get your pressures back in line
Old Jun 10, 2009 | 06:13 AM
batty200's Avatar
I have seen the pressure senders go bad frequently. Get a real guage in there and keep an eye on it. My old DSM did this only when the AC was on idling with the clutch in and the rod bearing on #1 and the b-shafts were toast and when I replaced it and removed the b-shafts the oil pressure was fine from then on.
Later
Old Jun 14, 2009 | 05:55 PM
adnmoh1's Avatar
i have the exact same problem right now, real rough idle with the oil flickering, checked oil levels, all are normal put in some lucas oil stabilizer but no effect taking to my garage to check out and see what ups, i have a mitsu tech manual also it says either, pressure switch, bearings, gears, or relief valve, need to firgure out whts up. this is so f!@@!ed up.
Old Jun 14, 2009 | 05:59 PM
EvoAlex48's Avatar
yeah i know, i just wish i could wake up and my car would be perfectly fine...=[
Old Jun 14, 2009 | 09:41 PM
ev0lution9's Avatar
if you have cams many people have this problem also. heres the link...hopefully it solves your problem
https://www.evolutionm.net/forums/ev...d-problem.html
Old Jun 15, 2009 | 08:19 AM
EvoAlex48's Avatar
im almost 100% sure my cams are stock, I mean, i wouldnt be suprised if they were MAYBE like 264's, is there anything written on them besides the manufacturer that would allow me to tell what kind of cams they are?
Old Jun 15, 2009 | 08:26 AM
EvoAlex48's Avatar
oh and thanks for the link, I was already going to change weight to prob like 15w-50, and after reading that thread it's pretty much convinced me the sensor is f*****, prob from when they put the engine or tranny back in,
Old Jun 20, 2009 | 11:39 PM
mitsuevo803's Avatar
bump, im having the same issue. just started happening. had the cams in for 1500 miles and then it started happening. after i installed my mbc it started happening. i checkd for leaks and none, i had 4500 miles on this oil change so changed oil, mobil 1 10w-30 and it helped a little bit. seems when the oil temp is over 85 degrees celcius it starts to flicker. hopefully its the damn oil pressure sending unit. ugh i hate cars lol...not really though
IzzyRS
35
Feb 22, 2012 06:34 AM
EvolutionEst
Jan 27, 2011 12:16 PM
WRECKLESS96
Aug 10, 2009 10:40 PM
Miguel@Denver
Sep 25, 2007 09:28 PM
xballsport
10
Jan 22, 2007 04:11 PM
