A question about evo 9 short block and evo 8 short block
Old Jun 10, 2009 | 08:36 PM
Knguyen228's Avatar
I have an Evo IX MR and I have fried one of my piston. I want to be on the safe side so I want to get a new short block. So far, I can only find an evo 8 short block, and I'm really not sure if the tranny is gonna fit, unless someone knows where I can find an oem evo ix mr shortblock so I know for sure it will fit. Any componets I can use to make my MR Tranny fit on an the evo 8 block? or is it impossible? I know there are conversion kit for 6spd MR shortblock to install a 5 spd.
I know I can just bore the motor out and make it to a 2.1/2.3L motor, but don't have the money for tuning and everything for it as I am currently working on my RX-7 since December.
ps: I already tried google and could not find it, and I don't want to buy a whole new motor, just a shortblock with all its componets is needed(pistons, crank, etc.), unless someone can get me a good condition Evo IX MR motor for under $3K, then I will be really happy.
It will be appreciated if anyone can help me out.
Old Jun 10, 2009 | 09:09 PM
alex_s817's Avatar
im pretty sure the bottom ends are exactly the same....?
Old Jun 10, 2009 | 10:45 PM
Knguyen228's Avatar
I thought there was a difference on how the tranny mounts. I know the bottom end is the same, but is there any difference in the bolt pattern for the tranny or something?
Old Jun 10, 2009 | 10:52 PM
Clutchdc5's Avatar
why dont u machine the block and put after market piston rods, crank since u only fried a piston
Old Jun 10, 2009 | 11:00 PM
hamx0r's Avatar
are you sure the evo 8 and 9 block are the same? i think the evo 9 has more oil passages in it cause of mivec... you should check that out...
Old Jun 10, 2009 | 11:03 PM
Knguyen228's Avatar
I thought of that, but I only have 3k. buying all the parts, machining the block, labor, and then tuning, you will be looking at over 6k easy, possibly more.
Old Jun 10, 2009 | 11:11 PM
casper980's Avatar
Dude, its a big piece of Iron, as long as you didn't gouge the bore past a certain point you can just bore it out and put a bigger piston in. Not to mention that they sell sleeves so you can have what ever bore you want even if its gouged. Use the money on machine work, internals, and the tune. Forget buying a new block. 4G63's are hard to come by and I think it would cost too much to change the VIII block over.
Old Jun 10, 2009 | 11:13 PM
hamx0r's Avatar
there is somebody for new york selling a built 9 motor that has low miles.... i think the price was around 3gs...
Old Jun 11, 2009 | 04:47 AM
20gmr's Avatar
^^^^^ wammy! viii and ix blocks are NOT the same. There is an extra oil feed to the head. How complicated it would be to make it work...idk? PS tranny's are interchangeable when it comes to bolting to the block. They have diffrent shifter cables and linkages but bolt up the same
Old Jun 11, 2009 | 08:07 AM
MOREPSiTEHBETT4's Avatar
do a buschur drop in/2500$ inspection+new rods+new pistons(price included iirc)
look up the drop in piston thread and db talks about it in there
Old Jun 11, 2009 | 03:28 PM
alex_s817's Avatar
this is what i meant, as far as the tranny pattern, the 6 speed should bolt up. good point about the mivec oil passages though, hah just like honda vtec blocks
rallykid
Dec 3, 2025 06:21 PM
badev0
22
Jun 7, 2016 09:59 PM
Blu3
Lancer Engine Tech
Mar 27, 2015 07:27 AM
iceman22
Aug 7, 2012 08:23 AM
kaonashi
10
Jul 1, 2007 10:26 AM
