Wastegate Question.
Old Jun 14, 2009 | 10:07 AM
Raceghost's Avatar
Wastegate Question.
Ok, so I have seen a 22 Psi wastegate on sale, and advertised. Does any one know the amount for the stock unit on my 2004 EVO 8 GSR? My Cobb Stage II tune, utilizes the hire boost pressure. Instead of utilizing the boost pill that Cobb made me, is this a better route? Will it do the job or am I missing something else?
Thanks in advance.
Old Jun 14, 2009 | 11:48 AM
Raceghost's Avatar
Bueller... Bueller...
Anyone? Are the stock units 1.5 bar? Is this a waste?
Old Jun 14, 2009 | 11:59 AM
sparky's Avatar
Why would you want to change out the stock WGA, anyway? Is there a reason that you are considering doung this? Probably the stock unit us just fine if setup right. It should do the job just fine for moderate boost levels under 25 PSI.
Old Jun 14, 2009 | 12:55 PM
Raceghost's Avatar
Someone had told me that the stock wastegate is only good to 20 psi max. DIdn't know if upgrading the wastegate was the better route then the boost pill?
Thanks you.
Old Jun 14, 2009 | 05:08 PM
huevosrancheros's Avatar
Im with sparky. Your wastegate should be fine for 25psi and under.
BUMP for some more info.
Old Jun 14, 2009 | 06:29 PM
evokid511's Avatar
yeah your wg should be plenty fine for atleast 20lbs theres some people running e85 on 30psi with stock wg...( im not one of them) but should be fine!
Old Jun 18, 2009 | 12:52 PM
Raceghost's Avatar
So the boost pill does it's job to hold it higher than 20psi, or is there something else I need to do. I thought one mod was to rig the spring, or change the spring out to hold more, another was the boost pill. Here I thought the wastegate in question that is stated to hold 22 psi, had an upgraded spring to hold the higher boost? What am I missing?
MoorzyRalliart
Apr 3, 2016 10:36 AM
Lanart2011
21
Mar 27, 2016 06:13 PM
ridenrunwv
Sep 21, 2015 12:54 PM
dudical26
42
Sep 7, 2009 06:06 PM
ST
May 11, 2007 08:06 PM
