Catch Can Help
Old Jul 13, 2009 | 10:15 AM
sdfontanini's Avatar
Catch Can Help
Wanted to make sure I was doing this correctly. Here's a diagram of how I setup my catch can configuration. Wanted to make sure I was doing this correctly, any help would be appreciated. Thanks in advance.
BTW I capped off my intake manifold inlet for the PCV side.
Old Jul 13, 2009 | 10:43 AM
Anyone?
Old Jun 8, 2010 | 09:17 PM
Bioxide02's Avatar
Sorry to bump an old thread, but does anyone have any input on this setup? I currently have my catchcan routed the same way.
Old Jun 8, 2010 | 09:55 PM
Xearo's Avatar
ditto just bought one.. hey did u guys fill yours with iron wool?? Guy told me to do that///
Old Jun 8, 2010 | 10:34 PM
tscompusa2's Avatar
yes its correct.
Old Jun 9, 2010 | 06:32 AM
Davo's Avatar
saikou michi and yes the routing from the pcv to the can and return line to intake is correct
Old Jun 9, 2010 | 10:10 AM
drb's Avatar
drb
Looks less than ideal IMO. Is the catch can vented or not vented? Do you use the stock MAF & if so is the line going from the catch can to the intake before or after the MAF?
Old Jun 9, 2010 | 10:35 AM
BEISSEN's Avatar
Look at your intake and it will answer that. The MAF sits right behind the Filter so the Intake Retune is beind the MAF.
Old Jun 9, 2010 | 11:11 AM
jessmanEVO's Avatar
Hmmmm.... I have mine setup differently. I just plugged the intake, took out the PCV valve and ran a straight thru fitting, and the return to the driver side valve cover fitting. So basically I have just the catch can connected to the two ports on the valve cover. I have a vented catch can the I bought from ATP turbo.
-Jesse
xmaciek82x's Avatar
Definitely not IRON wool. Those are too fine and will get sucked in. What you want is something like this:
http://www.amazon.com/214-Scotch-Bri.../dp/B000I1AEUW
The_X_Effect
Mar 16, 2014 06:29 AM
EvoDan2004
16
Aug 26, 2013 07:57 PM
Randal
Aug 27, 2012 06:09 PM
snafufx
Jul 21, 2012 12:06 AM
Hate_Times_Nine
Jan 28, 2012 07:58 PM
