ACD removal
ACD removal
Evo's comes with a factory acd system, is there any way to remove that system? is it save to do so?
my situation is that when I purchase my car the owner before me remove and cut some lines that go into the transfer case to include taking the pump out. Now I lost my transfer case and Im going to get an upgraded new one. what should i do? get new lines, pump and reconect everything factory or just install a new one and leave the acd system as it is now?
please advice. thx
please advice. thx
ACD is awesome. But it all come down to what needs to be replace and how badly you want it in your car. It will not be cheap.. It will not hurt anything if you don't have ACD connected. But I would recommend replace the T-case with a non ACD if you choose not to connect it.
if you want to remove the acd you must replace the transfer case with an 03-05 and take out the acd lines etc. I dunno about an engine code being thrown because im sure it has a harness to the ecu that would require more research. there are threads on here somewhere about someone doing this.
I'm pretty sure you can't just drive around an ACD case without the pump or lines. You will need to use a non acd tcase (from the 03-04).
https://www.evolutionm.net/forums/ev...d-removal.html
https://www.evolutionm.net/forums/ev...e-removal.html
tlcoll1
Feb 24, 2018 10:06 AM
WTB[SouthEast]: Wtb Evo 8 Non ACD Transfer case
Evo47
Jun 15, 2016 07:38 PM
MitsuJoe
468
Feb 20, 2016 11:17 AM
Gary@MellonRacing
Aug 29, 2014 02:25 PM
