Safe max rev limit on stock bottom end
Old Aug 10, 2009 | 06:31 PM
Makinahoe's Avatar
Hello all
I have an Evo 6.5 with HKS 272 Cams (with springs and retainers to suit)
I wanted to enquire on the maximum rpm limit with the stock pistons and rods.
Would 8000rpm be ok? (I an currently using a GT3076R 0.82a/r turbo)
I have searched though could not find anything substantial...
Thank You
Old Aug 10, 2009 | 06:35 PM
Spaceball 1's Avatar
How long do you want the motor to last?
Old Aug 10, 2009 | 06:41 PM
Makinahoe's Avatar
At least another 12-24 months?
Old Aug 11, 2009 | 06:46 AM
allinevo's Avatar
Originally Posted by Makinahoe
Hello all
Thank You
8k is pushing the outter limits of your stock rod bolts ability to hold the rotating assembly together. I have seen the stock bottom ends hold that for extended periods of time and I have also seen them come apart after just a few times in that RPM range so,it all depends on you. Also,how many miles are on the engine in question? The more miles the less likely it will like those rpm's.
Old Aug 11, 2009 | 07:22 AM
browningderek's Avatar
no more than 8k.
Old Aug 11, 2009 | 07:33 AM
gsrboi80's Avatar
118k on my 03 has seen 8k the better part of its life. Stock rod bolts
Old Aug 11, 2009 | 07:36 AM
BlueEvo61106's Avatar
My 2003 evo has been revving to 8K for awhile now and no problems yet!!! Stock bottom!
Old Aug 11, 2009 | 07:50 AM
allinevo's Avatar
As I posted eariler,some take it no problem and others go BOOM the first week you try it. Let some of the members who went boom chime in and you will see that there are just as many that break as last.
Old Aug 11, 2009 | 09:51 AM
deadbeatrec's Avatar
id worry about the head more than i would the lower end
Old Aug 11, 2009 | 09:54 AM
gsrboi80's Avatar
^ I'd agree with the above. I have springs and Ti Retainers in my head
Old Aug 11, 2009 | 10:15 AM
allday10sec's Avatar
on your evo 6 stock block i would say no dont do it. the evo 8 blocks i belive are more stronger. unlike the 7-5 evos. and im sure you know the weak crank in the evo4.
I just swaped out my evo 4 motor for a 8.
ooh by the way most people on here are from the us and dont know tomuchabout the older evos
Old Aug 11, 2009 | 10:16 AM
ooh i was thinking its a evo6 well isee its a 6.5 thats possible you will be ok sense the 6.5 used different rods and pistons.
Old Aug 11, 2009 | 10:23 AM
xspsi4's Avatar
A friend of mine was going mid 11's on a 6.5 tme for a year and revving 8,700 for over a year and had no problems with rod bolts, The thing that took that motor out was a topspeed race aginst a lexus isf at 190mph (6 speed swap)
Piston cracked a ring land.
EGbeater
Aug 30, 2023 09:09 AM
Randal
14
Sep 24, 2012 02:33 PM
babaz7
Jun 15, 2012 05:47 AM
toyotabike
Jun 9, 2011 02:51 PM
Craig King
17
Aug 16, 2009 07:43 AM
