pulling engine
Old Aug 22, 2009 | 06:41 AM
xcelr8's Avatar
pulling engine
Im rebuilding my car finally After a year of having a blown engine. Anyway, yesterday I pulled the entire engine out. We unbolted the trans and T-case from the block as well as apart from each other. there appears to be no more bolts to remove. But we cant seperate them. They are loose with a gap of about an inch, but they wont come apart. Am I missing a vital step? Thanks
Old Aug 22, 2009 | 07:05 AM
lemmysports2's Avatar
yes... you need to pull the output shafts out. youll need to get a slaphammer from your local autoparts store.
http://www.evomoto.com/tech_articles..._article_id=27
https://www.evolutionm.net/forums/ev...ual-links.html
hope this helps, helped me.... steve
Old Aug 25, 2009 | 07:11 PM
DragEvo9's Avatar
You need to disengage the clutch i had the same problem.. You can use a screwdriver..
Old Aug 25, 2009 | 07:21 PM
wevo1985's Avatar
both of the above guys are correct. you need to take the shafts out of the tcase to get that off the trans and you need to pop apart the throughout bearing from the pressure plate to get the trans off the engine.
Old Aug 25, 2009 | 07:24 PM
DragEvo9's Avatar
yep use a slide hammer with the bolt i used to know the size of the top of my head
Old Aug 25, 2009 | 07:30 PM
M8 x 1.25
Rival Legendary
Jul 7, 2015 06:34 PM
boosted169
Sep 28, 2014 10:01 PM
STIKiller4G63
Feb 25, 2012 09:35 PM
kaj
15
May 23, 2010 05:08 PM
c0r3y.aF
Sep 30, 2009 06:25 AM
